September 26, 2012, 09:19 |
iteration no. explodes, solution diverges
sinan
Rep Power: 13 |
Hi everyone,
after few steps from run begin, the No. of iterations for Ux, Uy, Uz, k and epsilon begin to explode then Co No. also explodes & the solution diverges. I'm using OF2.1, k-epsilon model, pisoFoam, 8-nodes. Thanks in advance for help. (please, tell me if you need more infos) |
September 26, 2012, 09:43 |
Rep Power: 14 |
some more information would be useful, i.e. - timesteps - geometry - size of cells - boundary conditions and so on . Without you just cam guess, why it doesnīt work! |
September 26, 2012, 10:11 |
sinan
Rep Power: 13 |
Hi Treima,
I have a flow around a cylinder (inlet, outlet, no-slip wall bed), cells no. is 4.5 million, time-step: I tried different values (from 1e-5 to 0.01 ) (the same happened with all, except sometimes more working iterations). I tried the same case (finer mesh) in OF1.6.x & it worked...I switched to OF2.1 because I have problem with parallel run in the older version. Please, tell me if you need more info. |
September 27, 2012, 02:45 |
Rep Power: 14 |
At the first moment i thought your timestep ist to large or your boundary conditions are wrong. But if the case worked in an older version of OpenFOAM, this is a little bit confusing. I donīt know, if there are any changes in OpenFOAM or in your case, which cause the mistake. Iīm not so familiar with the older versions...
And always give as much informations as possible! |
grid dependancy | gueynard a. | Main CFD Forum | 19 | June 27, 2014 21:22 |
smoothSolver diverges - solution in using PBiCG solver? | makaveli_lcf | OpenFOAM Running, Solving & CFD | 3 | September 11, 2013 12:44 |
residual plot after solution reset | plaunie | STAR-CCM+ | 1 | April 3, 2010 06:53 |
Solution calculations and convergence in Fluent | Freeman | FLUENT | 7 | May 3, 2009 22:26 |
Wall functions | Abhijit Tilak | Main CFD Forum | 6 | February 5, 1999 01:16 |
