May 8, 2009, 10:50 |
Parallel run diverges, serial does not
Samuel Braun
I have a case which runs fine in parallel with OpenMpi and serial without turbulence model. Unfortunately, the parallel run with turbulence model on (e.g. kE->LaunderGibsonRSTM) segfaults after few iterations. Whereas the serial run seems to converge (still running). Could this be a problem of the used preconditioner (p: GAMG, others: DILU)? Could someone, please, point me to a possible solution? Thanks and have a nice weekend. Samuel |
May 10, 2009, 03:28 |
Francesco Del Citto
Rep Power: 18 |
Hi Samuel,
there are a few threads about similar issues. Try to have a look to these two, for example: http://www.cfd-online.com/Forums/ope...tml#post215615 http://www.cfd-online.com/Forums/ope...llel-runs.html Hope this helps, Francesco |
diverge, mpirun, parallel, serial, turbulence |
Poisson eq w setReference works serial diverges in parallel | tehache | OpenFOAM Running, Solving & CFD | 5 | August 29, 2012 09:41 |
Script to Run Parallel Jobs in Rocks Cluster | asaha | OpenFOAM Running, Solving & CFD | 12 | July 4, 2012 22:51 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
Serial run OK parallel one fails | r2d2 | OpenFOAM Running, Solving & CFD | 2 | November 16, 2005 12:44 |
