May 26, 2009, 05:46 |
problems with turbFoam (small deltaT)
Sven Degner
I try to simulate a naca0012 with turbFoam (60degree) (picture attachment)
with this parameters: circle mesh around the naca ~500.000 cells (R~10m) finest cell on caca ~1e-4 patches are Naca = wall inletOutlet = the hole circle around the naca fronandback = cyclic Euler; gradSchemes linear; divSchemes upwind; adjustTimeStep (maxCo 1) RASModel LienLeschzinerLowRe; Re 10^6 Courant Number mean: 9.73987e-07 max: 3.02009 deltaT = 7.61855e-19 DILUPBiCG: Solving for Ux, Initial residual = 5.03753e-05, Final residual = 1.87688e-06, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.000688879, Final residual = 4.79751e-06, No Iterations 2 DILUPBiCG: Solving for Uz, Initial residual = 0.186895, Final residual = 9.20787e-07, No Iterations 2 DICPCG: Solving for p, Initial residual = 0.995746, Final residual = 9.57816e-06, No Iterations 494 time step continuity errors : sum local = 2.12007e-13, global = -2.51268e-16, cumulative = 6.45217e-14 DICPCG: Solving for p, Initial residual = 0.949774, Final residual = 9.6231e-06, No Iterations 493 time step continuity errors : sum local = 2.40166e-13, global = -2.255e-16, cumulative = 6.42962e-14 DICPCG: Solving for p, Initial residual = 0.955354, Final residual = 9.89174e-06, No Iterations 492 time step continuity errors : sum local = 2.47449e-13, global = -1.86303e-17, cumulative = 6.42776e-14 ExecutionTime = 474.19 s ClockTime = 474 s thats the facts, first of all i think openFoam are a implicit solver (Co unimportant), thats obviously not the case because the simulation broken up with to high deltaT As second step I try the option adjustTimeStep with a maxCo of 1, the conclusion is a very low timestep (|<1^ -20) and also a stop of the simulation after a few timesteps later whit this message DILUPBiCG: Solving for Ux, Initial residual = 4.20658e-05, Final residual = 2.20822e-06, No Iterations 1 [6] #0 Foam::error:rintStack(Foam::Ostream&)DILUPBiCG: Solving for Uy, Initial residual = 0.00129761, Final residual = 1.62481e-06, No Iterations 3 DILUPBiCG: Solving for Uz, Initial residual = 0.165781, Final residual = 1.73234e-06, No Iterations 2 in "/usrfem/femsys_local/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" [6] #1 Foam::sigFpe::sigFpeHandler(int) in "/usrfem/femsys_local/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" [6] #2 ?? in "/lib64/libc.so.6" [6] #3 void Foam:rocessorLduInterface::compressedSend<Foam:: Vector<double> >(Foam::Pstream::commsTypes, Foam::UList<Foam::Vector<double> > const&) const in "/usrfem/femsys_local/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so" [6] #4 Foam:rocessorFvPatchField<Foam::Vector<double> >::initEvaluate(Foam::Pstream::commsTypes) in "/usrfem/femsys_local/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so" [6] #5 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::evaluate() in "/usrfem/femsys_local/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/turbFoam" [6] #6 Foam::fvMatrix<Foam::Vector<double> >::H() const in "/usrfem/femsys_local/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/turbFoam" [6] #7 main in "/usrfem/femsys_local/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/turbFoam" [6] #8 __libc_start_main in "/lib64/libc.so.6" [6] #9 Foam::regIOobject::readIfModified() in "/usrfem/femsys_local/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/turbFoam" [dwoblx027:08797] *** Process received signal *** [dwoblx027:08797] Signal: Floating point exception (8) [dwoblx027:08797] Signal code: (-6) [dwoblx027:08797] Failing at address: 0x15d90000225d [dwoblx027:08797] [ 0] /lib64/libc.so.6 [0x2b53c21375b0] [dwoblx027:08797] [ 1] /lib64/libc.so.6(gsignal+0x35) [0x2b53c2137535] [dwoblx027:08797] [ 2] /lib64/libc.so.6 [0x2b53c21375b0] [dwoblx027:08797] [ 3] /usrfem/femsys_local/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so(_ZNK4Foam21processorLduInterfac e14compressedSendINS_6VectorIdEEEEvNS_7Pstream10co mmsTypesERKNS_5UListIT_EE+0xdf) [0x2b53c04a80cf] [dwoblx027:08797] [ 4] /usrfem/femsys_local/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so(_ZN4Foam21processorFvPatchField INS_6VectorIdEEE12initEvaluateENS_7Pstream10commsT ypesE+0x6a) [0x2b53c04aacda] [dwoblx027:08797] [ 5] /usrfem/femsys_local/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/turbFoam(_ZN4Foam14GeometricFieldINS_6VectorIdEENS _12fvPatchFieldENS_7volMeshEE22GeometricBoundaryFi eld8evaluateEv+0x1c6) [0x42c1f6] [dwoblx027:08797] [ 6] /usrfem/femsys_local/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/turbFoam [0x44c2d8] [dwoblx027:08797] [ 7] /usrfem/femsys_local/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/turbFoam [0x4156ff] [dwoblx027:08797] [ 8] /lib64/libc.so.6(__libc_start_main+0xf4) [0x2b53c2124ae4] [dwoblx027:08797] [ 9] /usrfem/femsys_local/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/turbFoam(_ZN4Foam11regIOobject14readIfModifiedEv+0 x199) [0x414119] [dwoblx027:08797] *** End of error message *** [DWOBLX018][0,1,1][btl_tcp_frag.c:202:mca_btl_tcp_frag_recv] mca_btl_tcp_frag_recv: readv failed with errno=104 [DWOBLX018][0,1,3][btl_tcp_frag.c:202:mca_btl_tcp_frag_recv] mca_btl_tcp_frag_recv: readv failed with errno=104 mpirun noticed that job rank 0 with PID 15544 on node DWOBLX018 exited on signal 15 (Terminated). 6 additional processes aborted (not shown) I got no idea what I can chance for simulation run with a not too small timestep. best wishes Sven |
May 26, 2009, 08:03 |
Wolfgang Heydlauff
Rep Power: 21 |
try Co=1
try frontAndBack = empty (not cyclic) try circle = inlet only |
Weird problems running unsteady | braennstroem | OpenFOAM Running, Solving & CFD | 5 | June 8, 2011 20:38 |
Problems about the selection among "turbFoam", "rhoTurbFoam" and "buoyantFoam" | chiven | OpenFOAM Running, Solving & CFD | 24 | June 16, 2009 08:44 |
Problems turbFoam | harwin | OpenFOAM Pre-Processing | 6 | December 7, 2006 05:36 |
Inlet problems with turbFoam | jonititan | OpenFOAM Running, Solving & CFD | 1 | May 4, 2006 03:24 |
silver surface and small edge problems | John | CFX | 2 | February 23, 2005 13:40 |
