gasoline spray simulation using dieselFoam
Old   June 14, 2009, 15:52
Default gasoline spray simulation using dieselFoam
qhdgj is on a distinguished road
Dear All,
Has anybody ever used the dieselFoam solver to simulate a gasoline spray/combustion? I just wonder which fuel did you use in your simulation? I could not find any fuel type with similar properties to gasoline in the fuel library in dieselFoam, like isooctane (C8H18)...
I appreciate any suggestions from you.
Thanks a lot,
-Jason
qhdgj is offline   Reply With Quote
Old   June 16, 2009, 11:35
Rachel Vogl
Rachel is on a distinguished road
Hi Jason,
http://foam.sourceforge.net/doc/Doxy...2d8a6a643.html
I guess that is the liquid you are looking for?
Rachel is offline   Reply With Quote
Old   June 16, 2009, 15:10
Thank you very much, Rachel.
-Jason
Old   June 19, 2009, 02:22
Rachel Vogl
Hi Jason,
Try changing to
CHEMKINFile "$FOAM_CASE/chemkin/chem.inp";
CHEMKINThermoFile "$FOAM_CASE/chemkin/therm.dat";
Old   June 22, 2009, 12:00
Default Gasoline injection and chemkin.inp setup
Simone Malaguti
malaguti is on a distinguished road
I'm trynig to simulate a gasoline injection starting from the aachenBomb tutorial. I need to change the chemkin.inp file in order to match with octane fuel propreties. May you suggest to me the costant values I have to use into the file to balance the reaction?
Thank you very much for your help
Simone
malaguti is offline   Reply With Quote
Old   June 23, 2009, 05:02
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
Simone
for a general reaction
C_xH_y + a O_2 -> b CO_2 + c H_2O
balancing C, H and O atoms.
C: x = b -> b= x
H: y = 2c -> c = y/2
O: 2a = 2b + c -> a = b + c/2 = x + y/4
niklas is offline   Reply With Quote
Old   June 23, 2009, 06:52
Simone Malaguti
Thank you very much, but my question was too general. I meant the three Arrhenius coefficients used in the chem.inp: I'm not able to find the correct values for octante reaction and at the same time I'm not able to understand the meaning of the last two variable of the file (I mean the two line "FORD" in the reported code for the eptane below).
ELEMENTS
H O C N AR
END
SPECIE
C7H16 O2 N2 CO2 H2O
END
REACTIONS
C7H16 + 11O2 => 7CO2 + 8H2O 5.00E+8 0.0 15780.0! 1
FORD / C7H16 0.25 /
FORD / O2 1.5 /
END
Old   June 23, 2009, 07:05
niklas's Avatar
Niklas Nordin
http://www.cvd.louisville.edu/Course/Chemical Vapour Deposition/Manuals/chemkin/chemkin1chemkin.pdf
page 29
the correct values are trickier...
Old   June 25, 2009, 15:51
have tried changing to "$FOAM_CASE/chemkin/therm.dat", but the problem is still there. I think the "therm.dat" file does not contrain any data of C8H18. I assume I need to use another thermophysical model rather than "hMixtureThermo<reactingMixture>". Do you guys have any further suggestions?
Thanks a lot,
-Jason
Originally Posted by Rachel View Post
Hi Jason,
Try changing to
Old   April 23, 2016, 03:01
Default diesel foam
HIMANSHU AGARWAL
himanhsu is on a distinguished road
I want to use C10H22 in place of C7H16 for this what changes i have to do
himanhsu is offline   Reply With Quote
Old   July 10, 2016, 01:55
mub
mubashar
mub is on a distinguished road
Hello Jason,
I have the same issue, i want to use iso octane rather than heptane; can you guide me how to do this.
mub is offline   Reply With Quote
Gasoline Spray Modeling sekkizhar Siemens 4 May 31, 2017 10:23
Gasoline Spray sekkizhar STAR-CD 7 April 17, 2009 07:31
Star crashed with spray simulation, please help! Jimmy Fox Siemens 4 October 17, 2006 16:09
problems with unsteady spray simulation Mathias FLUENT 1 July 20, 2006 16:13
Gasoline spray modelling Enrico Main CFD Forum 2 May 26, 1999 15:38
