Howto get the production and dissipation of TKE?? |
June 27, 2009, 04:44 |
Daniel WEI (老魏)
Rep Power: 21 |
Anyone knows how to get the production and dissipation of TKE (turbulence kinetic energy)? Thanks
Is it in this way: Code:
volSymmTensorField D = symm(fvc::grad(U)); //volTensorField Dprim = symm(fvc::grad(U - UMean)); volScalarField prod = -((U - UMean)*(U - UMean)) && D; volScalarField epsilon = sgsModel->epsilon();
~ Daniel WEI ------------- Boeing Research & Technology - China Beijing, China Last edited by lakeat; June 28, 2009 at 06:14. |
July 6, 2010, 10:55 |
Production and dissipation of TKE
Dear Daniel
I am also interested in this topic. Therefore, I would like to know if you found an answer to your question in the meantime. Cheers, Irina |
July 6, 2010, 11:26 |
Daniel WEI (老魏)
Rep Power: 21 |
Sorry, it'e been a long time, but doesn't the codes in my last post work for you?
you can try with a channel case and see if its distribution is correct. Bye
~ Daniel WEI ------------- Boeing Research & Technology - China Beijing, China |
December 13, 2010, 17:51 |
John Deas
why did you take the symmetrical part of grad(U) ? Why didn't you compute Code:
R && fvc::grad(Umean) Regards, JD |
December 14, 2010, 03:55 |
Alberto Passalacqua
Rep Power: 36 |
Notice that the method epsilon() returns the SGS dissipation rate. Check doxygen to see how it is computed, depending on the specific model.
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
December 14, 2010, 08:18 |
John Deas
Hi Alberto,
thank you for your answer. When I take a look at src\turbulenceModels\LES\incompressible\oneEqEddy\ oneEqEddy.C, I read: Code:
void oneEqEddy::correct(const tmp<volTensorField>& gradU) { GenEddyVisc::correct(gradU); volScalarField G = 2.0*nuSgs_*magSqr(symm(gradU)); solve ( fvm::ddt(k_) + fvm::div(phi(), k_) - fvm::laplacian(DkEff(), k_) == G - fvm::Sp(ce_*sqrt(k_)/delta(), k_) ); bound(k_, k0()); nuSgs_ = ck_*sqrt(k_)*delta(); nuSgs_.correctBoundaryConditions(); } Code:
ce_*sqrt(k_)/delta() Code:
2.0*nuSgs_*magSqr(symm(gradU)) I also do not understand why the symmetric part of the gradient of U is mentionned in the previous post. Regards, JD |
December 14, 2010, 09:34 |
David Boger
The double-inner product of a symmetric and asymmetric second-rank tensor is zero, so in that sense, only the symmetric part of gradU "survives" anyway. So using only the symmetric part is harmless, but perhaps unnecessary.
David A. Boger |
December 14, 2010, 11:21 |
#8 | |
Alberto Passalacqua
Rep Power: 36 |
volScalarField epsilon = sgsModel->epsilon(); does not return what you want. That epsilon is only the SGS epsilon. Since you do DNS, just apply the definition and you will be fine :-) Best,
July 9, 2016, 04:56 |
Syavash Asgari
Rep Power: 18 |
This is an old thread, but I wonder if anyone has achieved a reliable method to calculate TKE dissipation?! Regards |
March 22, 2022, 11:14 |
#10 | |
Rep Power: 5 |
Dear Johndeas, Did you find any way out ? I'm also stuck at the same state. |
Turbulent Dissipation Rates - epsilon | Otute | Main CFD Forum | 5 | May 20, 1999 10:51 |
