LES of Ribbed Channel
Old   June 29, 2009, 12:31
Default LES of Ribbed Channel
Matteo Baldi
Matteo85 is on a distinguished road
I'm working on the LES and DES simulation of the flow with heat transfer in a ribbed square channel (only one rib placed on one of the surfaces of the channel, on which surface a constant-heat flux condition is to be applied) with cyclic boundary conditions at inlet and outlet. I adopted a numerical work (by Liu, Tucker, Lo Iacono, 2006) as a reference for the setup of my case, in particular as regards the additional term that is required both in the momentum and in the energy equation as a consequence of the utilization of cyclic boundary conditions. The results of my calculations are not satisfactory in terms of velocity field above the ribbed surface, nor in term of distribution of Nusselt number: I'd like to know if anyone has had experience with this kind flow, in particular I'm interested in cross-checking the expression of the additional terms as well as the application of a fixed-gradient condition for the temperature at the heated wall to represent the constant-heat flux condition.
Your help would be really welcome,
Bye
Matteo
Matteo85 is offline   Reply With Quote
Old   June 29, 2009, 12:45
santos's Avatar
Jose Luis Santos
santos is on a distinguished road
Send a message via Skype™ to santos
What solver did you use? channelOodles?
Regards,
Jose Santos
santos is offline   Reply With Quote
Old   June 30, 2009, 02:42
Matteo Baldi
Hi Santos,
thanks for replying,
yes I've been using a solver that is based on ChannelOodles, I mean the momentum equation is solved as in ChannelOodles, but I've had to add the energy equation (equation for temperature). I've tried to use the energy equation in 2 forms: with a source term (as explained by Liu in the paper I cited in last post); without source term, but imposing a temperature jump between inlet and outlet.
As regards the momentum equation, although the authors of the cited paper report successfull results obtained with a source term similar to the one employed by ChannelOodles (i.e. calculated as a a mean quantity for the entire channel ), I'm not so sure this kind of source term is suitable for a channel with a rib.
Thanks again,
have a nice day
Matteo
des, heat transfer, les, ribbed channel
LES of turbulent channel flows cedric_duprat OpenFOAM Running, Solving & CFD 220 November 18, 2019 04:19
LES In Turbulent in channel flow pankaj saha Main CFD Forum 8 April 15, 2009 11:34
TURBELCE IN CHANNEL BY LES DANIEL Main CFD Forum 0 August 6, 2008 05:31
LES turbulence decaying in channel flow cfdIsMad CFX 4 July 4, 2008 06:29
Channel LES and explicit filtering Luca Liberti Main CFD Forum 0 January 17, 1999 10:07
