February 15, 2019, 05:04 |
Rough wave boundary layer
Dora
Dear Foamers,
I am trying to use interFoam to compute the wave-induced bed shear stress on rough bed. The problem is that I need very fine mesh near the bed ( in order of 0.2 mm) to capture the wave boundary layer. In case of smooth bed, this doesn't represent an issue . In this case interFoam results is in very good agreement with the experimental measurements for both laminar and turbulent conditions. The problem is when I am trying to model the rough bed. Then only way I could find to represent the surface roughness in OpenFOAM is by using one of the rough wall function (nutkRoughWallFunction or nutURoughWallFunction. When using this wall function at the beginning I noticed that the modeled bed shear stress is an order of magnitude smaller than the experimental values. Then I realized that at this mesh resolution, the rough wall function will not include the effect of the roughness since this require Y+ to be in order of 30. Actually this raise a question also regarding the validity of using a wall function for such fine mesh near the wall (Y+ in order of 1). I also discovered that the resulting bed shear stress is highly mesh dependent( increases when Y+ increase) So my question is, how I can model this rough surface in turbulent flow while preserving the mesh resolution? Any help is highly appreciated Kind regards |
shear stress, turbule model, wall functions, wave boundary conditions |
[snappyHexMesh] Help with Snappy: no layers growing | GianF | OpenFOAM Meshing & Mesh Conversion | 2 | September 23, 2020 08:26 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 08:44 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 04:39 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
