Running via SGE and mpich-mx
Old   August 3, 2009, 04:47
Default Running via SGE and mpich-mx
BastiL
bastil is on a distinguished road
Dear all,
I have build OF1.5-dev with support for you mpich-mx (myrinet cluster). SUbmitting a Job via SGE fails without any arrer message. The job simple does not start without any error. I use a script for submit:
#!/bin/sh
#$ -N OF_0013_mpich_mx
#$ -S /bin/sh
#$ -cwd
#$ -j y
#$ -pe mpi 32
export WM_MPLIB=MPICH-MX
source /opt/OpenFOAM/OpenFOAM-1.5-dev/etc/bashrc
echo $MPI_HOME
which simpleFoam
mpirun -machinefile $TMPDIR/machines -np $NSLOTS simpleFoam  -parallel </dev/null
I get mpich-Benchmarks running with that without problems but not simpleFoam. Any ideas?
bastil is offline   Reply With Quote
Old   August 3, 2009, 10:01
Assistant Moderator
Bernhard Gschaider
Originally Posted by bastil View Post
Dear all,
#!/bin/sh
#$ -S /bin/sh
#$ -cwd
#$ -j y
#$ -pe mpi 32
echo $MPI_HOME
which simpleFoam
I'm not sure whether your machines automatically know the PATH and where to find the libraries. Try adding to the mpirun
-x PATH -x LD_LIBRARY_PATH
In my setup I also transfer WM_PROJECT_DIR, FOAM_MPI_LIBBIN and MPI_ARCH_PATH, but I'm not 100% sure whether these are required (and as long as it works I see no harm in adding those)
If that doesn't work for you, have a look into the *.oxxx and *.poXXX-files that SGE gives you and share the error message there with us
Bernhard
Old   August 4, 2009, 04:27
BastiL
Thanks Bernhard for your help. I am still struggling.
Here is my submitscript:
#!/bin/sh
#$ -S /bin/sh
#$ -cwd
#$ -j y
#$ -pe mpi 32
echo $MPI_HOME
which simpleFoam
mpirun -machinefile $TMPDIR/machines -np $NSLOTS `which simpleFoam` /run/brblo OF_0013_mpich_mx -parallel -x PATH -x LD_LIBRARY_PATH < /dev/null
this is *.oXXX
/opt/OpenFOAM/ThirdParty/mpich-mx-1.2.7..5
/opt/OpenFOAM/OpenFOAM-1.5-dev/applications/bin/linux64GccDPOpt/simpleFoam
and this is *.poXXX
/opt/sge/default/spool/node006/active_jobs/5519.1/pe_hostfile
node006
node006
node006
node006
node030
node030
node030
node030
node003
node003
node003
node003
node026
node026
node026
node026
node027
node027
node027
node027
node004
node004
node004
node004
node025
node025
node025
node025
node020
node020
node020
node020
rm: cannot remove `/tmp/5519.1.all.q/rsh': No such file or directory
The Job does not even seem to start at all.
Old   August 4, 2009, 12:56
Assistant Moderator
Bernhard Gschaider
<snipped>
"Does not seem to start at all": What does that mean: The skript is hanging in the queue or simpleFoam/mpirun does not run?
No idea what could be the cause.
Just some tips for further testing:
- use qlogin to test it interactivly. Be aware that there are subtle differences between the environment you get with qlogin and qsub
- use less nodes and try to find out whether this is a problem that occurs if all processes are on one node, too (if not, then you might have a rsh/ssh-problem)
- MPI-demo programs run with the same script?
Bernhard
Old   August 4, 2009, 14:33
BastiL
No it is out of the queue imiditely with producing o and po files but without further output. It does not seem to do any serious work...
Yes, without any problem.
Old   August 5, 2009, 07:01
Assistant Moderator
Bernhard Gschaider
And running your script (with simpleFoam) in a qlogin-shell (you'll have to build the machine-file by hand)?
Sun Grid Engine grtabor OpenFOAM Running, Solving & CFD 28 August 22, 2012 09:27
Star-ccm+ batch mode on SGE Karl Jensen Siemens 0 February 4, 2009 15:54
