OpenFOAM - Validation of Results
Like Tree5Likes
  • 1 Post By Ahmed
  • 1 Post By henrik
  • 1 Post By Ahmed
  • 1 Post By paulo
  • 1 Post By niklas
Old   August 8, 2009, 13:21
Default OpenFOAM - Validation of Results
Ahmed
Ahmed is on a distinguished road
Being unhappy/disappointed with the results obtained by OpenFOAM after my first tutorial ( http://www.cfd-online.com/Forums/ope...-tutorial.html ) I decided to search for validation cases.
Searching the internet provides a good number of examples, but, in most of these cases, the results of OpenFOAM are presented as images, and comparing the results with those obtained by commercial solvers.
'This actually is not the correct way of validating a programme. When doing CFD analysis, the design engineer is looking for numerical values not pictures.
I decided to open this thread looking for your help. I hope the so many users of openFOAM can share their results with new users like me.
As a starter, I have prepared a case for the well documented flow over a flat plate, since we have the well known solution of Blasius.
Here is the blockMesh Dictionary
| \\ / O peration | Version: 1.6 |
| \\ / A nd | Web: http://www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1;
vertices
(0 0 0)
(1 0 0)
(1 0.1 0)
(0 0.1 0)
(0 0 0.1)
(1 0 0.1)
(1 0.1 0.1)
(0 0.1 0.1)
blocks
hex (0 1 2 3 4 5 6 7) (100 50 1) simpleGrading (1 15 1)
edges
patches
patch inlet
(0 4 7 3)
patch outlet
(1 5 6 2)
wall fixedWall
(0 1 5 4)
patch top
(3 2 6 7)
empty frontAndBack
(0 1 2 3)
(4 5 6 7)
mergePatchPairs
and the transport properties
| \\ / A nd | Web: www.OpenFOAM.org |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object transportProperties;
nu nu [ 0 2 -1 0 0 0 0 ] 15.08e-06;
here we have the controlDictionary
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
application icoFoam;
startFrom startTime;
startTime 0;
stopAt endTime;
endTime 0.01;
deltaT 1e-06;
writeControl runTime;
writeInterval 0.00015;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression uncompressed;
timeFormat general;
timePrecision 6;
runTimeModifiable yes;
here we have the initial conditions
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 101325;
boundaryField
inlet
type fixedValue;
value uniform 101325;
outlet
type zeroGradient;
fixedWall
type zeroGradient;
top
type fixedValue;
defaultFaces
type empty;
and the U file
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (100.0 0.0 0);
boundaryField
inlet
type fixedValue;
value uniform (100.0 0 0);
outlet
type zeroGradient;
fixedWall
type fixedValue;
value uniform (0 0 0);
top
type fixedValue;
defaultFaces
type empty;
I also attach images of the mesh and the results.
I am looking for your comments and corrections, but most importantly, I hope the readers will add their own validation cases
Luttappy likes this.
Ahmed is offline   Reply With Quote
Old   August 9, 2009, 03:01
Alberto Passalacqua
You just did the same: posted pictures
Out of joke, the idea of posting validation cases is surely interesting.
Alberto Passalacqua
Old   August 9, 2009, 03:38
Henrik Rusche
henrik is on a distinguished road
Dear Ahmed,
the Special Interest Group Turbomachinery is doing exactly what you describe.
http://openfoamwiki.net/index.php/Sig_Turbomachinery
They picked well-known validation cases
http://openfoamwiki.net/index.php/Si...ion_test_cases
ran the problem in different academic and commercial CFD groups compared the results with experimental data and presented the results at the workshop. The case setups and codes are available from sourceforge - So everybody can redo the exercise. Validation does not get better than this and it completely transparent - down to the last line of code.
Henrik
henrik is offline   Reply With Quote
Old   August 9, 2009, 11:00
Ahmed
That is correct, I posted the code and pictures hoping that readers can repeat the analysis and share their results and comments with the rest of us (Check the above post by Henrik Rusche)
You see, the U magnitude reported by my solution is greater than what I specified as the free stream condition, is my set up giving reasonable answers or is it the programme itself that is accumulating too much rounding errors?
Good luck and waiting to see your comments soon
immortality likes this.
Old   August 9, 2009, 11:03
Ahmed
Originally Posted by henrik View Post
Dear Ahmed,
ran the problem in different academic and commercial CFD groups compared the results with experimental data and presented the results at the workshop. The case setups and codes are available from sourceforge - So everybody can redo the exercise. Validation does to get better than this and it completely transparent - down to the last line of code.
Henrik
Henrik
Thanks for the information, I hope to see more validation cases on this forum
Good Luck
Old   August 10, 2009, 09:11
Andrew King
andersking is on a distinguished road
Dear Ahmed,
I believe your solution is correct. You have imposed a uniform fixed velocity at the inlet, and a fixed velocity on the top wall. As the boundary layer develops, the fluid within it slows down, and therefore to maintain mass continuity the fluid in the freestream region must speed up, above the 100m/s you have specified.
If you were to increase the height of your domain, then this "error" would be decreased. (also, you will likely observe a velocity gradient between the top surface, and the bulk flow).
Regards,
Andrew
Dr Andrew King
Fluid Dynamics Research Group
Curtin University
andersking is offline   Reply With Quote
Old   August 10, 2009, 09:28
Paulo Alexandre Costa Rocha
paulo is on a distinguished road
Dear Ahmed and All,
You can find a nice validation case here:
http://openfoamwiki.net/index.php/Bl...Flow_Benchmark
Hope that helps.
Best Regards,
Paulo Rocha
paulo is offline   Reply With Quote
Old   February 11, 2010, 19:13
Alberto Passalacqua
Originally Posted by lbuckley View Post
And if anyone knows of a good site for some fundamental examples, I would greatly appreciate it.
For the basic solvers (compressible/incompressible) the examples in the tutorial folder are relatively easy, even if I am well aware of the time it takes to learn OF ;-)
You can find some additional information on the wiki, but unfortunately explained tutorial are not many.
Best,
Alberto Passalacqua
Old   May 11, 2010, 04:50
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
New case added, LES around a square cylinder from the QNet-Ercoftac database,
Underlying Flow Regime 2-02.
http://openfoamwiki.net/index.php/Be...coftac_ufr2-02
mali likes this.
niklas is offline   Reply With Quote
Old   June 22, 2011, 18:59
Martin Hegedus
Martin Hegedus is on a distinguished road
I've started a similar thread here. http://www.cfd-online.com/Forums/ope...nfoam-v-v.html
A question that came up for me on that thread is what should one expect for the convergence of residual for steady viscous runs for incompressible external aerodynamics. It seems that one should not necessarily expect the pressure equation to converge lower than 1e-6.
So my question here is, how far did the residual converge for flat plate example given at the beginning of this thread? It's been a while since this thread was active, but thought I would give it a try.
Martin Hegedus is offline   Reply With Quote
Old   May 13, 2018, 18:28
Yuehan
wc34071209 is on a distinguished road
Are there more validation cases recently?
Thank you!
wc34071209 is offline   Reply With Quote
OpenFoam validation ranas OpenFOAM Running, Solving & CFD 0 July 7, 2009 05:56
OpenFOAM Training in Europe and USA hjasak OpenFOAM 0 August 8, 2008 05:33
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
Second OpenFOAM Workshop in Zagreb Croatia 79Jun2007 hjasak OpenFOAM 5 June 10, 2007 12:33
OpenFOAM Training and Workshop Hrvoje Jasak Main CFD Forum 0 October 7, 2005 07:14
