Difference between "ExecutionTime" and "ClockTime"
Like Tree21Likes
  • 1 Post By lakeat
  • 19 Post By Simon Lapointe
  • 1 Post By mathslw
Old   August 24, 2009, 06:44
Default Difference between "ExecutionTime" and "ClockTime"
lakeat's Avatar
Daniel WEI (老魏)
lakeat is on a distinguished road
Send a message via Skype™ to lakeat
Dear all,
A small question, what is the difference between "ExecutionTime" and "ClockTime"?
I can get these lins from icoFoam.C,
Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
<< " ClockTime = " << runTime.elapsedClockTime() << " s"
<< nl << endl;
someone said:
elapsedCPUTime() is the elapsed CPU time.
elapsedClockTime() is the elapsed wall clock time.
  1. Could anyone explain this in detail?
  2. If ClockTime means something, why then that we have to care about ExecutionTime?
  3. Is there any meaning concerning the ratio of ClockTime over ExecutionTime? Latency, or what?
  4. How can I change the writing format of these time, eg. show four decimal places in second.?
Thanks in advance for any reply.
rarnaunot likes this.
Daniel WEI
Boeing Research & Technology - China
Beijing, China
Email
lakeat is offline   Reply With Quote
Old   August 24, 2009, 06:56
Sandy Lee
sandy is on a distinguished road
Look at hani:
http://www.tfd.chalmers.se/~hani/kur...tyTutorial.pdf
in page 43.
sandy is offline   Reply With Quote
Old   August 24, 2009, 21:19
Simon Lapointe
Simon Lapointe is on a distinguished road
I'm not an expert but here's what I think,
1) There isn't much to add there, the ExecutionTime is the time spent by the processor and the ClockTime is the wall clock time or "real" time if you prefer.
2 & 3) There is an interest because a significative difference between the ExecutionTime and the ClockTime is a sign of a slow calculation. The difference can be explained by the time when a file is being written or when there is communication between processors in a parallel run. Using a computer with a slow interconnect or not enough cells per processor can cause a difference in cpu and clock time.
Hope that helps
Simon Lapointe is offline   Reply With Quote
Old   August 24, 2009, 21:58
lakeat's Avatar
Daniel WEI (老魏)
Originally Posted by Simon Lapointe View Post
Hope that helps
I noticed this is your first two posts on the forum, and they are so helpful, thank you.
Daniel WEI
Beijing, China
Email
Old   September 1, 2014, 10:53
Wei Liu
mathslw is on a distinguished road
Originally Posted by lakeat View Post
Dear all,
<< nl << endl;
Hi Daniel,
Have you found the answer to your 4th question? Thanks!
Wei
louisgag likes this.
mathslw is offline   Reply With Quote
Old   September 11, 2020, 09:52
louisgag's Avatar
Louis Gagnon
louisgag is on a distinguished road
Send a message via ICQ to louisgag
Originally Posted by mathslw View Post
Hi Daniel,
Wei
I had the same question and search a bit through the code.
It does not seem quite simple to do, or at least if it is I have not found how.
I think you would have to change the main code of OpenFOAM (I've looked at the .com version, pimpleFoam solver) or some of the principal libraries.
Here's my analysis, please jump in if you know more!
In the solver you call
runTime.printExecutionTime(Info);
and there are both
elapsedClockTime
elapsedCpuTime
printed. But both are not printed with the same precision.
elapsedCpuTime relies on the diff function which returns a scalar (double) coming from the C++ difftime function and elapsedClockTime relies directly on the C++ difftime function.
So the difference actually comes from the type of the arguments to the difftime function. For clockTime C++ time_t type is used and is in seconds. For cpuTime the call is to std::clock which returns a "processor time" which is no longer an integer.
The solution would be to somehow modify/rewrite the call from getTime to use chrono, something as what is given in here: https://stackoverflow.com/questions/...d-part-of-time
louisgag is offline   Reply With Quote
Old   September 1, 2023, 02:08
Default improve the precision of the excutive time
lxufeishi is on a distinguished road
Hi Daniel,
Wei
The "clockTime" Class would help, as its description:
"Starts timing and returns elapsed time from start. Uses std::chrono::high_resolution_clock for better resolution (2uSec instead of ~20mSec) than cpuTime. "
So the code would be like:
#include "clockTime.H"
Foam::clockTime myTime;
      //<< "  ClockTime = " << runTime.elapsedClockTime() << " s"
      << "  ClockTime = " << myTime.elapsedTime() << " s"
      << endl;
lxufeishi is offline   Reply With Quote
