August 24, 2009, 21:00 |
kOmegaSSTSAS model
Kyungrock Kim
Rep Power: 16 |
I've successfully simulated kOmegaSST in OF-1.5
but I got following error message using kOmegaSSTSAS in OF-1.6 Is there anybody that know what this problem is and how to resolve it? Thanks in advance #0 Foam::error:rintStack(Foam::Ostream&) in "/home/kkim64/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/kkim64/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/home/kkim64/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #4 void Foam::divide<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/home/kkim64/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libincompressibleRASModels.so" #5 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) in "/home/kkim64/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libincompressibleRASModels.so" #6 Foam::incompressible::LESModels::kOmegaSSTSAS::F2( ) const in "/home/kkim64/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libincompressibleLESModels.so" #7 Foam::incompressible::LESModels::kOmegaSSTSAS::upd ateSubGridScaleFields(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/home/kkim64/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libincompressibleLESModels.so" #8 Foam::incompressible::LESModels::kOmegaSSTSAS::kOm egaSSTSAS(Foam::GeometricField<Foam::Vector<double >, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&) in "/home/kkim64/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libincompressibleLESModels.so" #9 Foam::incompressible::LESModel::adddictionaryConst ructorToTable<Foam::incompressible::LESModels::kOm egaSSTSAS>::New(Foam::GeometricField<Foam::Vector< double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&) in "/home/kkim64/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libincompressibleLESModels.so" #10 Foam::incompressible::LESModel::New(Foam::Geometri cField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&) in "/home/kkim64/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libincompressibleLESModels.so" #11 Foam::incompressible::turbulenceModel::addturbulen ceModelConstructorToTable<Foam::incompressible::LE SModel>::NewturbulenceModel(Foam::GeometricField<F oam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&) in "/home/kkim64/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libincompressibleLESModels.so" #12 Foam::incompressible::turbulenceModel::New(Foam::G eometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&) in "/home/kkim64/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libincompressibleTurbulenceModel.so" #13 main in "/home/kkim64/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/pisoFoam" #14 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #15 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/i386/elf/start.S:122 |
August 25, 2009, 04:01 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi Kim
You divide by 0. This imply that you have put zero on either boundaries or internal volumes for k or omega. These needs to be finite, e.g. 1e-11. Best regards, Niels |
September 1, 2009, 22:59 |
Kyungrock Kim
Rep Power: 16 |
Thaks for the reply
Although I changed the values which you recommended but the same problem occurred. Is there any problem in code in itself? http://openfoamwiki.net/index.php/HowTo_debugging If there is some problem in code itself, how can I debug it(for specific files) Best regards, Kyungrock Kim |
October 19, 2009, 14:20 |
kOmegaSSTSAS on channelFoam
#4 | |
Kyungrock Kim
Rep Power: 16 |
Question) But is it viable at channelFoam. It looks possible, I guess, because I have the same error with in pisoFoam(dividing by zero blah blah...) but I couldn't overcome it yet. To make sure it. is it possible in your opinion and if it is, what's the difference to pisoFoam? |
October 19, 2009, 14:39 |
to clarify the problem
#5 | |
Kyungrock Kim
Rep Power: 16 |
Thanks in advance. |
February 4, 2010, 13:46 |
Pierre-Olivier Dallaire
Rep Power: 17 |
moved my post to Bugs - thanks
Reynolds Stress model in CFX vs Fluent | Tim | CFX | 1 | October 7, 2009 06:19 |
references about the fan/radiator model | Mihai ARGHIR | Main CFD Forum | 1 | January 8, 2001 15:49 |
references about the fan/radiator model | Mihai ARGHIR | Main CFD Forum | 0 | December 21, 2000 03:06 |
references about the fan/radiator model | Mihai ARGHIR | Main CFD Forum | 1 | December 17, 2000 07:01 |
references about the fan/radiator model | Mihai ARGHIR | FLUENT | 0 | December 17, 2000 06:40 |
