Large Eddy Simulation inlet
Old   August 27, 2009, 06:10
Default Large Eddy Simulation inlet
Prapanch Nair
prapanj is on a distinguished road
I am trying to simulate a wind tunnel case of flow over cylinder at a range of high Reynolds numbers. I was trying to simulate a certain length of the cylinder and cap the domain by symmetry Plane boundary conditions. I have values for inlet turbulent intensity, length scale etc. But I am not able to simulate a proper inlet as I don't have any idea how I can achieve a turbulent inlet. Could some one please suggest me some options ?
Thank You
Prapanj.
prapanj is offline   Reply With Quote
Old   August 27, 2009, 06:40
lakeat's Avatar
Daniel WEI (老魏)
lakeat is on a distinguished road
Send a message via Skype™ to lakeat
Is turbulent inlet crucial for your case?
What's your your les model?
What is the Re number?
Have you read the usersguide and noticed a turbulentInlet entry, will it meet your need?
Would you mind if the inlet is mapped from a channel flow case?
Daniel WEI
Boeing Research & Technology - China
Beijing, China
Email
lakeat is offline   Reply With Quote
Old   August 27, 2009, 07:22
Prapanch Nair
Hi lakeat,
In fact I was just reading another forum entry from you
I am not aware of a turbulent inlet entry. Is it just specification of the turbulent kinetic energy ? Because I think I will need upstream turbulence for this case.
How do I generate upstream turbulence using channel. I am aware of mapping fields but not aware how channel flow could get me some turbulence.
The reynolds number I am working is of the order of 10^6.
Do you think You have a suggestion?
Thanks,
Prapanj.
Old   August 27, 2009, 07:23
Prapanch Nair
Answering the left out questions,
I am using dynOneEqnEddy model.
Yes upstream turbulence is crucial for my case as I am dealing with coefficient of drag values. And I see these values are affected by my upstream turbulence.
Thanks
Old   August 27, 2009, 07:35
Prapanch Nair
Daniel,
I just checked the turbulentInlet and it looks like a good starting point. Do you think I could achieve better solutions with channel mapping?
What do they mean by a reference field and fluctuation scale? In other words how do we relate these to turbulence Intensity and average velocity? I hope I should get what I need by giving this BC to my velocity field right?
Thank You
prapanj.
Old   August 27, 2009, 09:19
Sandy Lee
sandy is on a distinguished road
Hi lakeat, if my case is an external flow but an internal flow, how can I get inlet k in the oneEqnEddy model?
sandy is offline   Reply With Quote
Old   August 29, 2009, 08:46
bjj
Bjarne Jensen
bjj is on a distinguished road
I have had some good results with the directMapping BC for generating the turbulent inlet for LES. This will also generate k on the inlet. Have a look in the pitzDailyDirectMapped tutorial.
You might also need to trigger the turbulence in the initial condition for example by using foamCalc randomize.
bjj is offline   Reply With Quote
Old   August 29, 2009, 10:31
lakeat's Avatar
Daniel WEI (老魏)
Thanks
Since you see they are affected by upstream turbulence, then I guess it would be a problem of turbulence transition, and then, will you get good prediction without set your 1st grid point around y+=1. And if so, have you considered whether you would afford for such a large computation? what is your grid numbers?
Daniel WEI
Beijing, China
Email
Old   August 30, 2009, 12:01
Prapanch Nair
Hi Bjj,
I see using direct Mapped boundary should be an option. But my concern is, what primer domain do I use to get the turbulence? I hear a lot about the channel flow that generate turbulence. But how does this primer region generate turbulence?
I am using OF 1.5.x. I don't see a tutorial that has pitzDailyDirectMapped. Or my chief concern is, where do I map my inlet from?
As for foamCalc randomize, don't I need some sort of regression to generate turbulence that has some time dependant properties? Will generating random numbers for U inlet help?
Thanks
Prapanj.
Old   August 30, 2009, 12:03
Prapanch Nair
Hi Daniel,
I hope I can go upto 2 million cells with my current computational ability. Still, I know my deltaT could be as low as 0.0001 for this kind of a problem for the Co to be within bounds. I am still ready to try that.
My chief concern is inlet turbulence though.
Thanks,
Prapanj.
Old   August 30, 2009, 13:52
bjj
Bjarne Jensen
Dear Prapanj,
With the directMapped BC you are recycling the turbulent quantatives from a mapping plane inside the domain back to the inlet. The mapping plane is defined with an offset distance from the inlet patch. I remember there are some different threads in the forum discussing this.
The pitzDailyDirectMapped tutorial is from OF 1.6 so you can try to have a look in that to see how it is set up. You can also find some description of this BC and other methods for generating turbulent inlet BC in Eugene De Villiers PhD. In general this is a good reference for les in OF.
With foamCalc randomize you can generate a pertubation in the U field as the initial condition simply to trigger the generation of turbulence. I think Eugene covers this as well in his PhD.
Regards,
Bjarne
Old   August 31, 2009, 08:45
Michael Roth
roth is on a distinguished road
OpenFOAM-1.5.x/tutorials/oodles/pitzDailyDirectMapped
roth is offline   Reply With Quote
Old   August 31, 2009, 09:06
Prapanch Nair
Thanks Mike
Btw, I was trying to use turbulentInlet BC. I assume the fluctuation scale is the turbulent intensity in each direction. The simulation seems fine, except that I can't make any sense out of pressure field. For a initial pressure field of 1e5, inlet zeroGradient and outlet fixedValue 1e5, I was getting a pressure field ranging from 9.6e4 to 1e5. And because of this, my Cd values kept oscillating from iteration to iteration. Should I be using a constant total pressure at inlet for a turbulentInlet in velocity ? (it should be working fine with zerogradient at inlet right? )
Thanks,
Prapanj.
cylinder, les, turbulent inlet, wind tunnel
Large Eddy Simulations usker Siemens 2 May 28, 2008 11:02
Flow around the ahmed body (large eddy simulation) Benzamia CFX 0 February 26, 2007 05:03
Detached Eddy Simulation Maged Ismail Main CFD Forum 4 June 10, 2005 08:28
LARGE EDDY SIMULATION Parshant Dhand FLUENT 0 May 19, 2003 22:12
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
