September 17, 2009, 06:30 |
create cyclic patch
Andrea Pasquali
Rep Power: 16 |
I'm trying to use createPatch to create a patch type cyclic coupling two patches (type patch). When I run createPacth I obtain: #0 Foam::error:: printStack(Foam::Ostream&) in "/home/openfoam15x/OpenFOAM/OpenFOAM-1.5.x/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigSegv::sigSegvHandler(int) in "/home/openfoam15x/OpenFOAM/OpenFOAM-1.5.x/lib/linux64GccDPOpt/libOpenFOAM.so" #2 __restore_rt at sigaction.c:0 #3 Foam::face::normal(Foam::Field<Foam::Vector<double > > const&) const in "/home/openfoam15x/OpenFOAM/OpenFOAM-1.5.x/lib/linux64GccDPOpt/libOpenFOAM.so" #4 Foam::cyclicPolyPatch::getCentresAndAnchors(Foam:: PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&, Foam::List<Foam::face> const&, Foam::List<Foam::face> const&, Foam::Field<Foam::Vector<double> >&, Foam::Field<Foam::Vector<double> >&, Foam::Field<Foam::Vector<double> >&, Foam::Field<double>&) const in "/home/openfoam15x/OpenFOAM/OpenFOAM-1.5.x/lib/linux64GccDPOpt/libOpenFOAM.so" #5 Foam::cyclicPolyPatch:: order(Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&, Foam::List<int>&, Foam::List<int>&) const in "/home/openfoam15x/OpenFOAM/OpenFOAM-1.5.x/lib/linux64GccDPOpt/libOpenFOAM.so" #6 Foam: polyTopoChange::reorderCoupledFaces(bool, Foam: polyBoundaryMesh const&, Foam::List<int> const&, Foam::List<int> const&, Foam::Field<Foam::Vector<double> > const&) in "/home/openfoam15x/OpenFOAM/OpenFOAM-1.5.x/lib/linux64GccDPOpt/libdynamicMesh.so" #7 Foam: polyTopoChange::compactAndReorder(Foam: polyMesh const&, bool, bool, bool, int&, Foam::Field<Foam::Vector<double> >&, Foam::List<int>&, Foam::List<int>&, Foam::List<Foam:: objectMap>&, Foam::List<Foam:: objectMap>&, Foam::List<Foam:: objectMap>&, Foam::List<Foam:: objectMap>&, Foam::List<Foam:: objectMap>&, Foam::List<Foam:: objectMap>&, Foam::List<Foam:: objectMap>&, Foam::List<Foam:: objectMap>&, Foam::List<Foam::Map<int> >&, Foam::List<int>&, Foam::List<int>&, Foam::List<Foam::Map<int> >&) in "/home/openfoam15x/OpenFOAM/OpenFOAM-1.5.x/lib/linux64GccDPOpt/libdynamicMesh.so" #8 Foam:: polyTopoChange::changeMesh(Foam:: polyMesh&, bool, bool, bool, bool) in "/home/openfoam15x/OpenFOAM/OpenFOAM-1.5.x/lib/linux64GccDPOpt/libdynamicMesh.so" #9 main in "/home/openfoam15x/OpenFOAM/OpenFOAM-1.5.x/applications/bin/linux64GccDPOpt/createPatch" #10 __libc_start_main in "/lib64/libc.so.6" #11 __gxx_personality_v0 in "/home/openfoam15x/OpenFOAM/OpenFOAM-1.5.x/applications/bin/linux64GccDPOpt/createPatch" Segmentation fault This is my createPacth dictionary: matchTolerance 1e-6; pointSync true; patches ( { name FAN_SERVER_1; type cyclic; constructFrom patches; patches (SERVER_1_INLET SERVER_1_OUTLET); } { name FAN_SERVER_2; type cyclic; constructFrom patches; patches (SERVER_2_INLET SERVER_2_OUTLET); } { name FAN_PORTA; type cyclic; constructFrom patches; patches (PORTA_LATO_CANTINA PORTA_LATO_CORRIDOIO); } ); Does anyone knowns where is the matter? Regards, Andrea |
Where's the singularity/mesh flaw? | audrich | FLUENT | 3 | August 4, 2009 01:07 |
CheckMeshbs errors | ivanyao | OpenFOAM Running, Solving & CFD | 2 | March 11, 2009 02:34 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
