conditions for unsteady problems
Old   November 7, 2009, 01:42
Unhappy conditions for unsteady problems
dvdromnu is on a distinguished road
I am solving unsteady state convective diffusion scalar equation using finite volume method(explicitly).
My problem is:
For steady state problem the solution converges at some time step and we get results. That means steady state problem is independent of initial conditions.
For unsteady state problem I am printing the values of scalar at a particular time step.
So My question is, for unsteady problem what initial conditions I have to take..?
means if I run unsteady problem for long time as in case of steady problem I am getting the same result of Steady state problem.
So, how I have to solve unsteady problem. What initial conditions I should take. What is the difference between unsteady state and steady state solutions
dvdromnu is offline   Reply With Quote
Old   November 7, 2009, 14:02
Alberto Passalacqua
If the problem admits a steady state solution, the unsteady solution procedure should lead to the same solution, if it is run long enough.
Alberto Passalacqua
Old   November 8, 2009, 00:45
Smile
Thank You................
Old   November 8, 2009, 01:52
Alberto Passalacqua
I'm sorry for the very vague answer. If you want more details, you should provide some more information about your problem.
Best,
Alberto Passalacqua
Old   November 9, 2009, 00:49
Default solution profile
Actually I want to know whether there is any difference in solution procedure of unsteady state and steady state scalar convective diffusion equation.
Also I want to know if we solve scalar equation with diffusion term only(without convection term) we will get one solution. Now, if we solve the same including convection term, we get another solution. So, adding convection term changes the solution profile( with only diffusion term) or it shifts the solution profile..?
Old   November 9, 2009, 02:15
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Hello .... dvdromnu (actually it would be nice to have a name here),
If the equations you're solving admit a solution, and if that solution is unique, then it doesn't matter what initial conditions you start with (as long as they are physical or representative for your equations).
If you're interested in the steady state solution, then again it doesn't matter what approach you use (steady/unsteady).
If the convection/diffusion equation has the same steady state solution as the diffusion only equation, then you will not see any "profile shift".
The only difference would be in the choice of the solver, and the amount of computational time requested (shorter for steady state and longer for unsteady).
I hope this was useful,
Dragos
dmoroian is offline   Reply With Quote
initial conditions, unsteady
Boundary conditions Cmesh high AOA pcasto OpenFOAM Running, Solving & CFD 3 February 5, 2009 06:04
Outlet conditions in BuoyantFoam jont OpenFOAM Running, Solving & CFD 2 October 15, 2007 07:55
Problems considering boundary conditions Morten Andersen CFX 1 January 18, 2007 09:04
Problems turbFoam harwin OpenFOAM Pre-Processing 6 December 7, 2006 05:36
compressible boundary conditions vivian Main CFD Forum 8 April 24, 2006 06:23
