Turbulence Model phi vs phi_
Old   July 3, 2007, 16:52
Default Hi all, I am trying to writ
Doug Hunsaker
doug is on a distinguished road
Hi all,
I am trying to write my own turbulence model and am currently studying the kEpsilon model in OF 1.4 linked with simpleFoam. In the simpleFoam.C source file, it says:
phi = fvc::interpolate(U) & mesh.Sf();
I'm not exactly sure what's happening here. My best guess is that it's interpolating the vector U from the cell centers to the cell faces and storing it as the transport property phi. (What exactly is the "& mesh.Sf()?)
In the kEpsilon.C source file, the dissipation equation is solved using phi_ as the item of transport. The divergence of phi_ is calculated as part of that equation. However, I thought you could only calculate the divergence of a vector. Is phi_ somehow a vector now instead of a scalar? If so, how was it set? I'm assuming that the phi defined in simpleFoam.C is the same as the phi_ in kEpsilon.C.
Since velocity is the item of transport, could the phi_ in the turbulence model be replaced by U_? This would be a true vector.
Thanks for your help.
Doug
doug is offline   Reply With Quote
Old   July 3, 2007, 19:50
Default Hi Doug, As I understand it
Shaun Cooper
coops is on a distinguished road
Hi Doug,
As I understand it fvc::interpolate(U) & mesh.Sf() is, as you say, the interpolation of the velocity from the cell centre to the cell face, the '&' is the dot product symbol, see programmer's guide, and meshSf() is the face area magnitudes.
So this is saying, interpolate the velocity field and take the dot product with the face area vector.
Not too sure about the rest,
Hope this helps,
Shaun
coops is offline   Reply With Quote
Old   July 4, 2007, 04:28
Default @"However, I thought you could
Assistant Moderator
Bernhard Gschaider
@"However, I thought you could only calculate the divergence of a vector. Is phi_ somehow a vector now instead of a scalar?": According to Gauss's theorem (http://en.wikipedia.org/wiki/Divergence_theorem) the divergence in a volume can be calculated by summing the flux on the surfaces. phi is just that (the flux on the surface). So I guess (havn't looked at the code for that) div(phi) does just that: sum up the phis on the surface and pretend it's div(U)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   July 4, 2007, 10:20
Default Hi Bernhard, If you think (
lam
Hoang-Lam
lam is on a distinguished road
Hi Bernhard,
If you think (as Shaun) that div(phi) is something like div(U), do you think that I have well implemented:
nu*laplacian(U)=grad(div(U))/epsi
(I obtained this expression by considering:
div(U)=epsi*p, where epsi is very small
(epsi [0 -2 1 0 0 0 0] 1e-6))
and
nu*Laplacian(U)=grad(p)
by writting in Foam:
tmp<fvvectormatrix> UEqn(laplacian(nu,U));
solve(UEqn()==fvc::grad(fvc::div(phi)/epsi));
Lam
lam is offline   Reply With Quote
Old   November 10, 2009, 04:33
isabel
isabel is on a distinguished road
In OpenFOAM you can compute div(U) which is correct because U is a vector.
However, phi is a "surfaceScalarField" (not a vector). What div(phi) is? And why you can compute a divergence of an scalar? By definition, divergence is applied to a vector, for a scalar it would be a gradient.
isabel is offline   Reply With Quote
which turbulence model to use??? Ravikanth CFX 1 April 3, 2008 18:03
Turbulence Model GG Siemens 3 March 3, 2008 19:06
changing model constants in k-e turbulence model Sunil CFX 3 October 3, 2006 12:12
Best Turbulence Model manish FLUENT 1 March 10, 2005 18:15
HELP! TURBULENCE k-e OR k-omega TURBULENCE MODEL? Mirek Kabacinski FLUENT 5 August 24, 2003 22:31
