Motorbike Tutorial
Old   November 16, 2009, 14:14
Thumbs up Motorbike Tutorial
stark22 is on a distinguished road
Hello everyone.
I'm a new member so I apologise for my ignorance.
I've been working through the tutorials and decided to attempt the motobike tutorial.
I manage to generate the mesh using blockmesh, snappyHexMesh.
I still am unable to see the bike in paraFoam even after searching through the various threads. Someone mentioned reduce the xmin and ymax but I wasnt able to locate these options. Thoughts? Should I continue to suffer for a right of passage?
It appears that this tutorial contains boundary conditions so I assumed I could run icoFoam or simpleFoam to obtain a solution. Is this correct.
In attemp to run icoFoam and simpleFoam is closes by saying the following:
Create time
Create mesh for time = 3
Reading transportProperties
Reading field p
--> FOAM FATAL IO ERROR:
cannot open file
file: /home/adam/OpenFOAM/OpenFOAM-1.6.x/tutorials/incompressible/simpleFoam/motorBike/3/p at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 62.
FOAM exiting
I looked at the "3" folder which I believe is the final mesh folder and was not able to locate "p at line 0"
Thanks everyone for the help.
stark22 is offline   Reply With Quote
Tutorial for subcooled nucleate boiling Asghari FLUENT 42 December 10, 2018 11:42
Problem on Fluent Tutorial: Horizontal Film Boilig Feng FLUENT 2 April 13, 2013 05:34
FoamToEnsight/EnsightParts/VTK not working with motorbike tutorial madad2005 OpenFOAM Bugs 5 October 18, 2009 04:48
ensightToFoam error with motorBike tutorial az_monger OpenFOAM 2 August 17, 2009 14:45
Rotor/stator tutorial, and how to... gilberto CFX 5 January 21, 2002 09:41
