shockTube simulation different solvers
Old   November 18, 2009, 20:30
Default shockTube simulation different solvers
Eelco Gehring
feijooos is on a distinguished road
Hi All,
I am working on simulating a shockTube in OF. I noticed that there are several shockTube tutorials available. I ran some of these, but I am confused what solver to pick. Do sonicFoam and rhoCentralFoam etc. give the same results?
Besides that, I noticed that the shocktube velocity in sonicFoam becomes sub-sonic. Isn't sonicFoam only for sonic flow?
In general, I am wondering what solver to use for this kind of problem?
I want to simulate the driver section with 2000 kPa and the driven section under atmospheric pressure (101.3 kPa). Temperature on both sides will be 300 K.
Thanks for you help!
feijooos is offline   Reply With Quote
Old   November 19, 2009, 04:33
Default rhoCentralFoam
KrisT is on a distinguished road
I tried the shock tube tutorials in OpenFOAM before rhoCentralFoam. They give the wrong results (shock speed and states are wrong). You should use rhoCentralFoam (or maybe the new AeroFOAM - http://www.cfd-online.com/Forums/ope...-aerofoam.html).
If you wish you could test the solution against an analytical one, check the code in this link http://num.math.uni-goettingen.de/kn...ro_ss2006.html
KrisT is offline   Reply With Quote
Old   November 19, 2009, 10:49
Eelco Gehring
thanks for the help, comparing against an analytical solution is a great idea!
Thanks,
Eelco
Old   November 19, 2009, 11:14
Eelco Gehring
btw, do you have any idea why sonicFoam gives the wrong solution? This gets me thinking why the tutorial is given in the first place....
Old   November 19, 2009, 15:09
No, but maybe scheme is not conservative?
Old   November 19, 2009, 15:22
Eelco Gehring
hmm I was more thinking in the line of this: sonicFoam is only for sonic flow and a shocktube will always have sub-sonic flow.
Old   November 20, 2009, 04:10
Jean-Peer Lorenz
jploz is on a distinguished road
have a look at the following Master thesis by B. Wuethrich: 'Simulation and validation of compressible flow in nozzle geometries and validation of OpenFOAM for this application'. This work deals with shock tube problems and the solvers in OF (stat.ethz.ch/rw/alumni/thesis/Wuethrich_Benjamin_Masterarbeit.pdf). Nice work.
Good luck.
Jean-Peer
jploz is offline   Reply With Quote
Old   November 20, 2009, 10:44
Eelco Gehring
Very nice documentation on this project indeed. This will be very helpful.
Thanks,
Eelco
Old   November 20, 2009, 17:20
Eelco Gehring
Jean-Peer, I read through the document and verified several OF solver. They seem to line up very well against the analytical solution, especially rhoCentralFoam and rhopSonicFoam. Others are not so good, such as sonicFoam, which makes sense.
This was very helpful. Thanks
Replacing mesh while running a simulation akultane CFX 1 November 15, 2009 13:46
FSI TWO-WAY SIMULATION Smagmon CFX 1 March 6, 2009 13:24
Continuous vs interrupted simulation sega OpenFOAM Running, Solving & CFD 4 November 3, 2008 14:29
Fire simulation using FDS from NIST Jens Main CFD Forum 1 January 22, 2004 01:53
3-D Contaminant Dispersal Simulation Apple L S Chan Main CFD Forum 1 December 23, 1998 10:06
