December 11, 2009, 09:03 |
calculating parallel on two machines
Tim
Hi there,
maybe becaus of i am very new at open Foam i got a big problem. i try to calculate on two different machines and i dont know how to synchronizes my 8 cores. i think at this moment i am on the wrong way and i hope that someone could give me an interresting impulse |
December 11, 2009, 09:07 |
Rep Power: 16 |
have you added the -parallel argument to the execution command?
For example a very simple execution command on 2 processors with pisoFoam looks like this: mpirun -n 2 pisoFoam -parallel For 2 different machines you should add a machine file as described in the user guide. |
December 11, 2009, 09:09 |
re
Tim
yep i startet a process succesfull with 4 cores on one machine... i think there can only be a very little aspect i have overlooked ....
Maybe in my decomposepardic file.... |
Script to Run Parallel Jobs in Rocks Cluster | asaha | OpenFOAM Running, Solving & CFD | 12 | July 4, 2012 22:51 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
Fluent cases in parallel across multiple machines | Riaan | FLUENT | 3 | April 11, 2005 11:51 |
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 | Amitava Majumdar | Main CFD Forum | 0 | January 5, 1999 12:00 |
