interFoam in 1.6.x, solver's slightly changed from 1.5; is p = pd?
Old   December 15, 2009, 05:14
Default interFoam in 1.6.x, solver's slightly changed from 1.5; is p = pd?
kjetil is on a distinguished road
Dear foamers,
I have been using 1.6.x and the interFoam/compressibleInterFoam for a pipe flow, and the results look satisifying. However, the pressure values seem to be way too low. Comparing to previous OF releases, the pressure field is now used as 'p', not as 'pd'. Does this mean that solver has changed, or is the 1.6 'p' equal to the 1.5 'pd'? Can I still use the 1.5-dev interFoamPressure-utility, or won't this be necessary?
Thanks.
kjetil is offline   Reply With Quote
Old   December 15, 2009, 18:41
Masashi Ohbuchi
Ohbuchi is on a distinguished road
Hi, Kjetil.
Please refer to the release note for version1.6;
http://www.opencfd.co.uk/openfoam/do...Notes-1.6.html
5.1 Solver restructuring
pd replaced by static pressure p. All solvers in which buoyancy affects might be strong have been converted from using pd to p with improved numerics to give equally good accuracy and stability. This change is prompted by the need to remove the confusion surrounding the meaning and purpose of pd.
Ohbuchi is offline   Reply With Quote
Latest git 1.6.x: Crash when using inletOutlet for variable alpha1 in interFoam carsten OpenFOAM Bugs 6 September 23, 2009 09:46
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
