the result of pitzDaily using simpleFoam and pisoFoam
Old   February 15, 2010, 13:12
Default the result of pitzDaily using simpleFoam and pisoFoam
Kyungrock Kim
Kr_kim is on a distinguished road
Dear Formers
I've performed bunch simulations for pitzDaily case(Experimental inlet and directMapped etc.) using simpleFoam and pisoFoam.
However, the results, especially streamwise mean velocity profile are pretty
different even at tutorial case between two solvers. I've simulated locDynOneEddy, OneEddy, Spalart-Allmaras(LES), and k-epsilon, kOmegaSST, SpalartAllmaras(RAS)
Weirdly, RANS results is better than those of LES.
I suspect that pisoFoam is not correct.
Are there any observation from this type of simulations?
Thanks
Kyungrock
Kr_kim is offline   Reply With Quote
Old   March 16, 2010, 13:38
Paul Garlick
pg22 is on a distinguished road
One thought: are the RANS and LES cases grid independent?
I have run the tutorial cases in OF 1.5 and also noticed the large differences in the results. However, the grid is the same for both cases. For the LES case it is likely that a finer grid is required.
pg22 is offline   Reply With Quote
pimpleFoam vs simpleFoam vs pisoFoam vs icoFoam? phsieh2005 OpenFOAM Running, Solving & CFD 45 March 22, 2021 09:14
LES tutorial for pitzDaily hhuang84 OpenFOAM Running, Solving & CFD 0 October 12, 2009 12:38
