Turbulent flow of two incompressible fluids with the same physical properties |
December 10, 2009, 12:07 |
Arne Babenhauserheide
Rep Power: 16 |
Can OpenFOAM simulate the injection of two different incompressible fluids with the same physical properties (when it comes to fluid dynamics), including turbulent flow. Can it output the result in a way which allows me to visualize the fraction of the fluids at every point? I've been testing OpenFOAM the last two days, but I didn't find a clear answer (neither here nor via Google). I looked at the sloshingTank3D (interDyMFoam) and the elbow (icoFoam), as well as some others. What I couldn't answer for myself: * Can I add injection of a specific fluid instead of setting a general velocity field? * Can I "tag" a fluid, so I can identify it in ParaView? * Does both work with turbulent flow? (I currently evaluate different options for simulating contrast fluid in blood vessels) |
December 10, 2009, 14:46 |
#2 | |
Michael Prinkey
Rep Power: 25 |
December 11, 2009, 04:32 |
Rep Power: 16 |
Hi mprinkey,
Many thanks for your answer! I now played a bit with a passive scalar field, and it seems to do exactly what I need. Just to be sure I don't go into completely unrelated directions: Did I understand you correctly, that the next step now is to grab the source for a turbulent solver (for example turbFlow) and add the passive scalar equation (for example taken from the scalarTransportFoam)? Best wishes, Arne |
January 5, 2010, 05:48 |
found
Rep Power: 16 |
I now found the second answer myself - two weeks winter vacation and google helped -> yes, I have to build my own solver (turbulence + scalar field). And it doesn't seem horribly complicated - means I found a guide which shows the basics:
http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam Many thanks! |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Natural convection - Inlet boundary condition | max91 | CFX | 1 | July 29, 2008 20:28 |
Moving mesh turbulent incompressible flow of complex meshes | philippose | OpenFOAM Running, Solving & CFD | 5 | March 13, 2007 03:35 |
2D incompressible turbulent flow | na | Main CFD Forum | 5 | June 2, 2005 11:02 |
Turbulent incompressible flow & moving boundaries | Cristian Orozco | Main CFD Forum | 1 | July 5, 2002 12:45 |
