Swirl at inlet boundary
Old   January 6, 2010, 18:05
Default Swirl at inlet boundary
kjetil is on a distinguished road
Dear foamers
I would like to have a swirl as inlet condition for a single phase flow, preferably when using simpleFoam. I can only find engineSwirl, and no proper documentation - it there any other way to get this property to an inlet BC?
kjetil is offline   Reply With Quote
Old   January 7, 2010, 03:00
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Originally Posted by kjetil View Post
Dear foamers
Attached is a swirl inlet velocity boundary condition that I have kicking around. Unfortunately I don't actually know in what condition it is (I haven't needed it for several years), but you might give it a try anyhow.
olesen is offline   Reply With Quote
Old   January 7, 2010, 05:20
Franco Marra
francescomarra is on a distinguished road
I would also suggest the lecture of the excellent wiki page of the Sig Turbomachinery at the following link:
http://www.openfoamwiki.net/index.ph...Turbomachinery
Following the link to the Validation test cases you will find explanation about an alternative way to set swirling boundary conditions.
Hope this help.
Franco
francescomarra is offline   Reply With Quote
Old   January 10, 2010, 17:08
Thanks francescomarra, have you tried this one on OF 1.6(.x) ?
Old   January 10, 2010, 17:29
Franco Marra
I was able to compile and use the addSwirlAndRotation utility. It is simple and almost self explaining. It uses the constant/swirlAndRotationDict to define the angular velocity of swirl and the rotation vector.
After having defined the normal component of inlet velocity and interior initial velocity in the file 0/U , by running this utility you get the same file modified to take into account the swirling applied to the boundary and, if desired, to the initial conditions.
It was easy to modify this routine to get different swirling velocities for two coaxial annular jets.
Let me know if you need further details.
Regards,
Franco
Old   January 10, 2010, 17:37
Ok. Upon compiling, I get the error " cannot find -lincompressibleTurbulenceModels", also when doing a "full" build of the OSIG-dir.
Did you compile only the preProcessing-directory, or the entire OSIG-package found in the 'Breeder' directory in the SVN?
Old   January 11, 2010, 16:47
Problem solved using what's found in trunk 'Breeder_1.5', not just 'Breeder'.
Old   May 13, 2010, 17:12
Default Problems with compiling addSwirlAndRotation on OF 1.6.x
stonehope's Avatar
Patrik Steinhoff
stonehope is on a distinguished road
Hey foamers,
i am quiet new to OF and get in trouble by compiling addSwirlAndRotation following the wiki (http://openfoamwiki.net/index.php/Si...diffuser#Case1).
I am using Ubuntu and OF 1.6.x.
First i thought it depends on compiling under OF 1.6.x, but after using google i found this thread.
Can anyone maybe help me al little to fix the errors i get.
By typing:
stonehope@ubuntu:~/OpenFOAM/stonehope-1.6.x/applications_SIGturbo/utilities/preProcessing/addSwirlAndRotation$ wmake
I get the response:
Making dependency list for source file addSwirlAndRotation.C
could not open file geometricOneField.H for source file addSwirlAndRotation.C
SOURCE=addSwirlAndRotation.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/stonehope/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude -I/home/stonehope/OpenFOAM/OpenFOAM-1.6.x/src/turbulenceModels/RAS -I/home/stonehope/OpenFOAM/OpenFOAM-1.6.x/src/transportModels -IlnInclude -I. -I/home/stonehope/OpenFOAM/OpenFOAM-1.6.x/src/OpenFOAM/lnInclude -I/home/stonehope/OpenFOAM/OpenFOAM-1.6.x/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/addSwirlAndRotation.o
In file included from /home/stonehope/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/fvm.H:44,
from /home/stonehope/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/fvCFD.H:10,
from addSwirlAndRotation.C:33:
/home/stonehope/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/fvmDdt.H:41:31: error: geometricOneField.H: No such file or directory
/home/stonehope/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/fvmDdt.H:63: error: expected ‘,’ or ‘...’ before ‘&’ token
/home/stonehope/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/fvmDdt.H:65: error: ISO C++ forbids declaration of ‘geometricOneField’ with no type
In file included from /home/stonehope/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/fvmDdt.H:90,
/home/stonehope/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/fvmDdt.C:63: error: expected ‘,’ or ‘...’ before ‘&’ token
/home/stonehope/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/fvmDdt.C:65: error: ISO C++ forbids declaration of ‘geometricOneField’ with no type
/home/stonehope/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/fvmDdt.C: In function ‘Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::ddt(int)’:
/home/stonehope/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/fvmDdt.C:67: error: ‘vf’ was not declared in this scope
In file included from /home/stonehope/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/fvm.H:47,
/home/stonehope/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/fvmLaplacian.H: At global scope:
/home/stonehope/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/fvmLaplacian.H:88: error: expected ‘,’ or ‘...’ before ‘&’ token
/home/stonehope/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/fvmLaplacian.H:91: error: ISO C++ forbids declaration of ‘geometricOneField’ with no type
/home/stonehope/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/fvmLaplacian.H:96: error: expected ‘,’ or ‘...’ before ‘&’ token
/home/stonehope/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/fvmLaplacian.H:98: error: ISO C++ forbids declaration of ‘geometricOneField’ with no type
In file included from /home/stonehope/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/fvmLaplacian.H:188,
/home/stonehope/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/fvmLaplacian.C:133: error: expected ‘,’ or ‘...’ before ‘&’ token
/home/stonehope/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/fvmLaplacian.C:136: error: ISO C++ forbids declaration of ‘geometricOneField’ with no type
/home/stonehope/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/fvmLaplacian.C: In function ‘Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::laplacian(int)’:
/home/stonehope/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/fvmLaplacian.C:138: error: ‘vf’ was not declared in this scope
/home/stonehope/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/fvmLaplacian.C: At global scope:
/home/stonehope/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/fvmLaplacian.C:146: error: expected ‘,’ or ‘...’ before ‘&’ token
/home/stonehope/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/fvmLaplacian.C:148: error: ISO C++ forbids declaration of ‘geometricOneField’ with no type
/home/stonehope/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/fvmLaplacian.C:148: error: redefinition of ‘template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::laplacian(int)’
/home/stonehope/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/fvmLaplacian.C:136: error: ‘template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::laplacian(int)’ previously declared here
/home/stonehope/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/fvmLaplacian.C:150: error: ‘vf’ was not declared in this scope
make: *** [Make/linuxGccDPOpt/addSwirlAndRotation.o] Error 1
I just got the files from:
svn checkout http://openfoam-extend.svn.sourcefor...y/applications applications_SIGturbo
and
svn checkout http://openfoam-extend.svn.sourcefor...oMachinery/src src_SIGturbo
that means the ../Breeder1_5/..-directories as mentioned above.
I am happy for any request(s).
Thanks.
stonehope
stonehope is offline   Reply With Quote
Old   May 13, 2010, 17:38
You just need the application dir in postProcessing called 'addSwirlAndRotation'. Make a svn checkout, and do "wmake", that's it.
And make sure you do this inside the OpenFOAM environment. I put this in an application folder under my "<user>-1.6.x" ...
Old   May 13, 2010, 18:23
stonehope's Avatar
Patrik Steinhoff
hey kjetil,
greateful thanks for your quick help!!!
I tried as you told me, but finally it did not start working.
Searching for possible Reasons guided me to the problem with geometricOneField.H .
It is discussed at
http://www.cfd-online.com/Forums/ope...ion-error.html
and updating the corresponden link(s) solved my problem.
Compiling is no Problem anymore.
Thx.
stonehope
Old   July 23, 2010, 18:42
Sina
shajitah is on a distinguished road
Dear foamers,
I really enjoyed your forum discussion about addSwirlAndRotation. Actually, I've compiled addSwirlAndRotation successfully, but it doesn't make any "swirlAndRotationProperties" dictionary file. So, I was just wondering if you could please provide me with a sample of "swirlAndRotationProperties" dictionary file or show me a link of download.
I look forward to hearing from you.
Thanks a lot,
Sina
shajitah is offline   Reply With Quote
Old   July 24, 2010, 05:28
stonehope's Avatar
Patrik Steinhoff
when you take a look to:
http://openfoamwiki.net/index.php/Si...se0:_Base_case
Here you can find something like this:
"....In the swirlAndRotationProperties dictionary you also specify the swirl/rotation in terms of the omega[radians per second] vector and the center of rotation vector. The switches modifyBoundaries and modifyInterior can be modified to control if both the boundaries and the interior should be modified, or only one of them.
An example of the swirlAndRotationProperties dictionary can be found in Case1."
According to this you can find the swirlAndRotationProperties under:
https://openfoam-extend.svn.sourcefo...tionProperties
What you see then should look like this:
| \\ / O peration | Version: 1.5.x |
| \\ / A nd | Web: http://www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object swirlAndRotationProperties;
modifyBoundaries yes;
modifyInterior yes;
omega omega [0 2 -1 0 0 0 0] (0.0 0.0 52.646);
center center [0 0 0 0 0 0 0] (0.0 0.0 0.0);
rotatingPatches (
inlet
rotSwirlWall
Use this to set your own rotating swirl.
PS: Don't forget to update the BC's for the use of addSwirlAndRotation.
Old   August 31, 2010, 15:41
Default Swirl and rotation does not work in compressible flow solver?
  #13
yu
universez is on a distinguished road
Hi, is this working with compressible flow?
I tried sonicFoam and rhoPisoFoam, none of them give reasonable results.
any suggestion?
Thanks,
Yu
Originally Posted by stonehope View Post
FoamFile
version 2.0;
format ascii;
class dictionary;
modifyInterior yes;
rotatingPatches (
inlet
rotSwirlWall
universez is offline   Reply With Quote
Old   August 31, 2010, 15:50
The rotating inlet is changing your inlet velocity field only, shouldn't be any further problem with the solver itself.
Old   September 1, 2010, 13:58
yu
Hi, Kjetil,
you are right, the solver is ok.
The problem i think is because paraview did not show correct results. See the attached pictures (Case1.3 from http://openfoamwiki.net/index.php/Si...nical_diffuser).
I plotted the z componet of vector U (U Z) and Uz calcualted from foamCalc (sliced by the plane in the z direction and passing point(0,0,0)). They are different. I checked U file and know the file is ok. I think there is something wrong with paraview.
Thanks,
yu
Old   December 10, 2012, 09:14
wided
wiedangel is on a distinguished road
Hi all,
I am trying to compile the addSwirlAndRotation utility but I get the followinf error, I guess about the decomposer metis:
>> wmake
SOURCE=addSwirlAndRotation.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/wi/OpenFOAM/OpenFOAM-1.6-ext/src/finiteVolume/lnInclude -I/home/wi/OpenFOAM/OpenFOAM-1.6-ext/src/turbulenceModels/RAS -I/home/wi/OpenFOAM/OpenFOAM-1.6-ext/src/transportModels -IlnInclude -I. -I/home/wi/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/wi/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64Gcc46DPOpt/addSwirlAndRotation.o
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/wi/OpenFOAM/OpenFOAM-1.6-ext/src/finiteVolume/lnInclude -I/home/wi/OpenFOAM/OpenFOAM-1.6-ext/src/turbulenceModels/RAS -I/home/wi/OpenFOAM/OpenFOAM-1.6-ext/src/transportModels -IlnInclude -I. -I/home/wi/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/wi/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64Gcc46DPOpt/addSwirlAndRotation.o -L/home/wi/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64Gcc46DPOpt \
-lincompressibleRASModels -lincompressibleTransportModels -lfiniteVolume -lmeshTools -lOpenFOAM -liberty -ldl -lm -o /home/wi/OpenFOAM/wi-2.1.1/applications/bin/linux64Gcc46DPOpt/addSwirlAndRotation
/usr/bin/ld: warning: libmetis-parmetis.so, needed by /home/wi/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64Gcc46DPOpt/openmpi-system/libparMetisDecomp.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libparmetis.so, needed by /home/wi/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64Gcc46DPOpt/openmpi-system/libparMetisDecomp.so, not found (try using -rpath or -rpath-link)
/home/wi/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64Gcc46DPOpt/openmpi-system/libparMetisDecomp.so: undefined reference to `ParMETIS_V3_PartGeomKway'
collect2: ld returned 1 exit status
make: *** [/home/wi/OpenFOAM/wi-2.1.1/applications/bin/linux64Gcc46DPOpt/addSwirlAndRotation] Error 1
does any of you know how I can solve this compilation error?
Thank you in advance.
Regards,
widedangel
wiedangel is offline   Reply With Quote
Old   September 17, 2013, 12:24
Default Problem with addSwirlAndRotation
  #17
Maciej
maciejaser is on a distinguished road
This is my first post. I've problem with paraview or another. In my case (simple cylinder) I've swirl on face "inlet". Swirl is forced by utility named "applications_SIGturbo". My mesh is made in enGrid and it has boundary layer on cylindrical wall. Inlet velocity is 1 (one) m/s. I use simpleFoam (openFoam) to solve it. Problem is, when i start paraview (paraFoam 4.0) the velocity has very very big value (over 1000 m/s !!!) but behavior of a swirl is properly. Does anyone know what is wrong?
thanks for help.
maciejaser is offline   Reply With Quote
Old   January 7, 2014, 04:52
Lower your relaxation factors in the beginning.
Old   July 6, 2017, 15:08
Gajendra Gulgulia
ggulgulia is on a distinguished road
there is no mention of swirl here
ggulgulia is offline   Reply With Quote
Old   October 19, 2017, 02:46
Default How to add swirl at inlet BC
  #20
tiwari is on a distinguished road
Hi, I am using openFoam4.1. I want to add swirl at my inlet to the axisymmetric jet but unable to implement.
I tries using
inlet
type swirlFlowRateInletVelocity;
flowRate constant 0.2;
rpm constant 100;
uniform value (1 0 0)
I saw the previous post but none were helpful.
Please suggest and guide.
tiwari is offline   Reply With Quote
Pressure Inlet Boundary Condition Prasad FLUENT 6 April 9, 2013 21:32
Inlet and outlet boundary condition David Baker FLUENT 3 June 22, 2005 00:42
Pressure Inlet Boundary Condition Trinity_psu FLUENT 0 June 1, 2005 14:15
user soubroutine of inlet boundary conditions Charlie Beghein Siemens 2 August 30, 2002 02:03
length scales at inlet for internal flows Anne-Marie Giroux Main CFD Forum 3 July 5, 1999 21:28
