If OpenFOAM can run different solver in different domain in the same time ?
Old   February 17, 2010, 03:57
Default If OpenFOAM can run different solver in different domain in the same time ?
Jiang
panda60 is on a distinguished road
Dear all,
I want to know If OpenFOAM can run different solver in different domain in the same time .
for example:
In the left domain, I want to use pisoFoam to generate turbelence, while in the right domain, I want to use buoyantBoussinesqPisoFoam.
Is it possible in Foam ? and how can I do this ?
I think this is an interesting problem.
panda60 is offline   Reply With Quote
Old   April 10, 2014, 04:17
adarsh tiwari's Avatar
adarsh tiwari
adarsh tiwari is on a distinguished road
Hi All,
This is almost the same thing i am also asking,
In a particular domain, I want to solve for heat transfer in the fluid at initial stage, as the flow passes to middle domain i have to solve for heat transfer as well as magnetic field while in the end of the domain i have to solve the combination of electric-magnetic and thermal effect.
This all is to be done in the same structure at different location for e.g., consider a pipe of 1 m. length then for first 30 cm i have to solve for heat transfer after leaving 5 mm gap again for next 30 cm and so on, as explained above.
It would be great help!!!
Thanks and Regards,
Adarsh R. Tiwari
adarsh tiwari is offline   Reply With Quote
Old   May 14, 2014, 23:40
adarsh tiwari
still nothing..??????
Old   May 15, 2014, 04:27
Olivier
olivierG is on a distinguished road
hello,
Take a look at chtMultiRegionFoam. There is fluid and solid region, but you can add other region (porous, mhd, ...) or modify fluid/solid region.
But you need to do some coding to do that.
regards,
olivier
olivierG is offline   Reply With Quote
Old   May 15, 2014, 10:07
adarsh tiwari
Hi Olivier
thanks for your quick response, as soon as i'll do something i'll get back to you
Thanks and Regards,
Adarsh R. Tiwari
Suggested unsteady, implicit solver stable with arbitrarily large time steps djbungee OpenFOAM Programming & Development 45 March 23, 2015 04:14
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
Modifying gravity vector and MRFomega a run time nico765 OpenFOAM Running, Solving & CFD 3 December 22, 2007 10:41
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
