March 8, 2010, 09:52 |
print position of Lagrangian particle?
Sven Degner
Rep Power: 17 |
hi foamers,
I'm work at the moment with icoLangrangianFoam. icoLagrangianFoam is a simple Solver exactly like icoFoam, bur with Lagrangian particle. Now, i have problem with the position of the Lagrangian particle. For the post processing I want to follow the particle trace with a simple loop. For this loop I need the position particle, but everyone of my try s fail. Know everyone how I can print the x,y and z position of Lagrangian particle? thy for any help, Sven |
March 8, 2010, 11:09 |
Andrew Ryan
Rep Power: 17 |
I'm not sure if I understood your question correctly. There is a folder called lagrangian in the folder of every timestep. It contains a folder with the name of the could and a file called positions..
March 9, 2010, 02:58 |
matej forman
Rep Power: 17 |
Another possibility would be to use particleTracks from $FOAM/applications/utilities/postProcessing/lagrangian which creates particle tracks for paraview from where you can export the data to a file. There's also other way, to add a bit of coding into your solver to dump the positions or any other info about your particles. search in src directory for dumpParticlePositions or writePostions function (as in basic/Cloud/Cloud.H). The only problem with this solution is, that the IOstream is that it cannot append, so you will have loads of files for each time-step. but easy script will sort it out I guess.
hope this helps matej |
March 9, 2010, 07:09 |
Andrew Ryan
Rep Power: 17 |
I didn't know about the particle tracks utility.. thx for the hint
June 16, 2016, 08:58 |
Alaska1964
Rep Power: 11 |
Hi Matej,
I am trying to track the location of the particles but i dont know how. In my case particles are injected from 4 different regions and I want to see where these particles are located after 1 second of calculations. In other words I want to learn the location of the particles with respect to their release position. I would be glad if you could help me. Kind regards, Alex |
Lagrangian particle tracking | jiejie | OpenFOAM | 15 | July 19, 2017 11:18 |
Lagrangian Particle Tracking model In CFX | Kushagra | CFX | 8 | December 2, 2010 21:18 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 01:29 |
Particle position undetermined first time step | Amine | FLUENT | 0 | March 4, 2009 05:01 |
how to know position of particle in PTK | areriko | CFX | 0 | November 19, 2007 21:19 |
