Hiting the wall by particle
Like Tree1Likes
Old   April 12, 2010, 04:40
Default Hiting the wall by particle
Mihails Ščepanskis
shchepan is on a distinguished road
Hello!
I have a problem with the particles tracking. The problem is to simulate the hit of the particle to the wall (the boundary of the mesh) correctly.
There is solidParticle library in the OpenFOAM. The function trackToFace in solidParticle.C should take into account the size of the particle in the case of collision. But if the cell near the wall is smaller then the size of the particle doesn't work! In this case particle can approach the wall closer than the radius of the particle.
Can you tell me how can I solve this problem?
Mihails Ščepanskis
Laboratory for Mathematical Modelling of Environmental and Technological Processes
University of Latvia
shchepan is offline   Reply With Quote
Old   April 12, 2010, 04:57
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
yup, that is correct.
I think this is a deliberate limitation, because what you want to do is very expensive.
Also, particles can only belong to 1 cell at a time, so how do you treat this?
This should also be considered, but again, extremely expensive to solve.
N
niklas is offline   Reply With Quote
Old   April 13, 2010, 03:10
matej forman
matejfor is on a distinguished road
in more detail, what Niklas is mentioning - the lagrangian particle tracking implemented in FOAM is sitting on the assumption, that the particle is smaller than the cell. Otherwise you would need to integrate e.g. the forces on particle around the particle surface as it expands over more cells. New formulation of coupling to the continuous phase would be needed. The continuous phase would not be continuous any more -- force transfer across particle.... You would need to use VOF, or 6DOF or some other treatment...
matej
matejfor is offline   Reply With Quote
Old   April 13, 2010, 03:47
Mihails Ščepanskis
Niklas and Matej, thank you very much for answer!
Matej, you are right that in the case of big particle we should take into account a lot of forces (for example lift force, that takes into account the circulation of the flow around the particle). I have already implemented this and some other forces in the solidParticle library.
The most problem is in the region close to the wall. We should make the size of the mesh elements near the wall much smaller than in the middle zone to simulate the hydrodynamic correctly, especially in the case of EM governed flow (my case). Thus appears the described problem of the collision with the wall.
The way how to solve this problem that I want to suggest is so. I propose to make a virtual wall in the distance of the radius of the particle from the real wall. Then make the size of the particle zero for the function wallImpactDistance. Thus we will indicate the collision when the center of the particle reach this virtual wall.
Now I can not understand how to implement the check of the collision with this virtual wall in the function trackToFace. If you can give me some advise in this question, I'll be very thankful!
Mihails Ščepanskis
Old   April 13, 2010, 09:12
niklas's Avatar
Niklas Nordin
This is a really difficult problem.
Let me outline how I would do it and where I see the challenges. Maybe you have a better idea, in which case I would love to hear it.
Since we are assuming that wall-interaction can occur even though we are not in a cell close to a wall, we have to move our wall-faces inwards according to the wallImpactDistance and check every wall-face before we move the particle to see if we will hit a wall face first.
This operation is pretty straight-forward: we just add 1 extra check to the original algorithm
before we move the particle.
Something like this -
1. original algorithm.
2. check wall faces.
3. move particle.
However...point 2 in the list above is trickier than one would think
Maybe a simple example can serve as an illustration to the problem.
Assume we have 2 walls as below, that we move inwards and
the particle wants to move from A to B.
        ______________
          A -> __B________                      A ->        B
                /           2                                      /
           1  /                                 ====>        /
              /    outside                                    /
All faces on wall 1 will intersect with the trajectory A-B, but none will actually be hit.
Hence, when you check for wall-interaction you have to also check if the intersection-point
is within the wall-face.
And, since we have to take into account the size of the particle and move the wall-faces, we
are creating small holes in the mesh through which the particle can escape.
So in short, wall-interaction has to take into account if the interacting point is within the face (very expensive check) and it's also important when you move the wall-faces that you
dont create holes in the mesh. This implies that you cant just move the faces, you have to move the points that constitutes the faces.
I hope it is clear now why I find this a bit difficult.
N
Old   April 13, 2010, 12:54
Default Query
Sumit Sinha
forsumit is an unknown quantity at this point
Hey Guys,
May be you all can help me, I have been trying to play with Lagrangian particle solver, I had two questions in this regard
a) Is there some restriction on this solver, when we run it in parallel.
b) I have even tried running it on my desktop, every thing keeps on going well for certain time steps but eventually it hangs with message on the screen as follows
Time = 0.41
Courant Number mean: 0.0123124 max: 0.234255
Moving Particles
53 Particles moved. 3 walls hit. 0 particles left the model.
DILUPBiCG: Solving for Ux, Initial residual = 0.000270292, Final residual = 8.83653e-08, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.000453004, Final residual = 9.93462e-07, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 0.00126948, Final residual = 1.39543e-06, No Iterations 1
DICPCG: Solving for p, Initial residual = 0.0139312, Final residual = 0.00119803, No Iterations 3
DICPCG: Solving for p, Initial residual = 0.00276161, Final residual = 0.00026989, No Iterations 56
time step continuity errors : sum local = 6.67705e-08, global = -5.95145e-09, cumulative = 8.18682e-07
DICPCG: Solving for p, Initial residual = 0.00173553, Final residual = 0.000171299, No Iterations 8
DICPCG: Solving for p, Initial residual = 0.00126418, Final residual = 0.000115941, No Iterations 8
time step continuity errors : sum local = 2.8673e-08, global = -6.02904e-09, cumulative = 8.12653e-07
ExecutionTime = 597.83 s ClockTime = 598 s
Time = 0.42
Courant Number mean: 0.0123111 max: 0.23442
Moving Particles
It just does't proceed beyond this
All other residuals seems to be under control and courant number is well below zero. I am also attaching the file cloudProperties, Any help is enormously appreciated.
Thanks,
Sumit
forsumit is offline   Reply With Quote
Old   April 14, 2010, 02:24
Mihails Ščepanskis
Niklas,
you are right, there are a lot of problems in your example of 2 walls and obtuse angle between them. Let us initially consider simpler case. Let we have some simple geometry, for example cylinder (there are no obtuse angles). In this case we can build the virtual wall in the distance of particle radius from the real wall.
You propose to apply some function to indicate heating this virtual wall before the move function. But now algorithm check heating with the wall inside of move function. There are trackToFace function that indicate the collision and move the particle only to the face of cell or wall. Thus we should implement this new check into the trackToFace function, but not outside of the move function, as you suggest.
Am I right?
Sumit,
where are some problems with parallel calculation when you are working with the big cloud (huge number of particles). I have not solve this problem yet.
Mihails Ščepanskis
Old   April 14, 2010, 03:01
niklas's Avatar
Niklas Nordin
Originally Posted by shchepan View Post
Niklas,
Am I right?
yes, you are right, but that's what I ment.
it will all be in the trackToFace routine. It has to be.
trackToFace checks all faces in the cell to see if the particle can move to its end position
or if it should move the particle to the intersecting face.
What I meant was that before we move it (which is actually done inside the trackToFace routine) we have to add an additional check for all, and I do mean all, wall faces before we can go ahead and move it.
And I really dont recommend that you implement something that will work only on a special type
of geometry.
Old   April 14, 2010, 04:35
Mihails Ščepanskis
Niklas,
I am very thankful for your help and ideas!
But I want to ask you some more technical questions.
There is such code in Particle.C:
00307 // change cell
00308 if (internalFace) // Internal face
00309 {
00326 }
00327 else
00328 {
00329 ParticleType& p = static_cast<ParticleType&>(*this);
00341 if (!p.hitPatch(patch, td, patchi))
00342 {
00371 else if (isA<wallPolyPatch>(patch))
00372 {
00373 p.hitWallPatch
00374 (
00375 static_cast<const wallPolyPatch&>(patch), td
00376 );
00377 }
00382 }
00383 }
Here is indicated the collision with the wall and applied the hitWallPatch method. But I cannot understand how to add the new virtual wall to the list of faces and to put flag that it is the wall, not cell face.
Can you help me in this question?
As a next step I'll think how to patch up the possible holes in the virtual wall.
Mihails Ščepanskis
Old   April 14, 2010, 05:00
niklas's Avatar
Niklas Nordin
That part of the code is just responsible for the wall-treatment and will remain unchanged.
What you want to do is to edit the Particle.C-file and the trackToFace-routine.
just stick an include-file there and add the necessary checks and the rest should work,
since boundary-faces are moved according wallImpactDistance.
Just remove the check in the lambda-routine that wallImpactDistance is shorter than cell-size also of course.
Hitting a face is signalled with facei_ not being equal to -1.
So when you have moved the particle to the virtual wall, setting facei_ accordingly,
the tracking will think it is on a wall and apply the boundary treatment.
template<class ParticleType>
template<class TrackData>
Foam::scalar Foam::Particle<ParticleType>::trackToFace
    const vector& endPosition,
    TrackData& td
    const polyMesh& mesh = cloud_.polyMesh_;
    DynamicList<label>& faces = cloud_.labels_;
    findFaces(endPosition, faces);
    // check for all boundary faces here and if a face has been hit
    // add it to the faces variable, the rest of the code should remain unmodified
    #include "myWallCheck.H"
    facei_ = -1;
    scalar trackFraction = 0.0;
    if (faces.empty())  // inside cell
        trackFraction = 1.0;
        position_ = endPosition;
    else // hit face
        scalar lambdaMin = GREAT;
Old   April 14, 2010, 08:58
Mihails Ščepanskis
Niklas,
I understand, that in myWallCheck.H I should check the wallImpactDistance in direction of normal vector of face for all faces. If this wallImpactDistance for the faces[j] is less than d_/2.0 then we should redefine this faces[j] as a boundary face. And all other algorithm will work.
But
1) how can I get the normal vector of faces[j]?
2) how can I mark this faces[j] as a boundary face?
Thank you a lot, Niklas!
P.S. I think I have found answer on the 1st question:
mesh.Sf()[facei_]/mesh.magSf()[facei_]
Am I right?
Mihails Ščepanskis
Old   April 14, 2010, 09:55
niklas's Avatar
Niklas Nordin
Niklas,
But
Am I right?
correct, and if the face is on a boundary the normal is pointing outwards.
You dont have to mark a face as a boundary face. FOAM knows if the face is a internal face or not.
You just have to loop over every patch and check if its a wall or not, then
you can just grab the faces of an entire patch and loop over those.
not sure of the exact syntax, but to grab them should be something like this
const surfaceVectorField& Sfbi = mesh.Sf().boundaryField()[patchi];
or
const faceList& bcfaces = mesh.cells().boundaryMesh()[patchi] alternatively
mesh.boundaryMesh()[patchi].cells()
(not sure how it is)
Also, remember that cells() returns the indeces to the faces, while faces() returns the indeces to the points.
if it doesnt work try looking in the wallFunctions directory for the turbulenceModels
should be something useful there
If you cant figure it out I will try to find out the exact expression.
Old   April 14, 2010, 10:28
Mihails Ščepanskis
Sorry, Niklas, I don't understand your algorithm:
I just don't understand.
What I proposed:
Thus I suggest to deceive the FOAM and tell it that boundary face is not real boundary face, but the face of the cell, when the particle in this cell is closer to the real wall than d_/2.0. If it is possible, of course.
Niklas, would you be so kind to explain me the algorithm you suggest and/or estimate my one?
Mihails Ščepanskis
Old   April 15, 2010, 04:55
niklas's Avatar
Niklas Nordin
I am away at a conference at the moment, but when I get back
I will write you a piece of code that I think will make it clear.
N
Old   April 15, 2010, 05:25
Mihails Ščepanskis
Thank you very much, Niklas! I'll be waiting for code.
Have a good time on the conference!
Mihails Ščepanskis
Old   April 15, 2010, 15:12
niklas's Avatar
Niklas Nordin
On a train back home, lets hope the shaky connection works
Here's how you access all the stuff you need.
I'm leaving it up to you to fill out the details, i.e, how you check if
the face-hit is within the face-edges
myWallCheck.H
const polyBoundaryMesh& patches = mesh.boundaryMesh();
const pointField& points = mesh.points();
forAll(patches, i)
    const polyPatch& patchi = patches[i];
    if (isA<wallPolyPatch>(patchi))
        const vectorField& Sfbc = patches[i].faceAreas();
        const vectorField& Cfbc = patches[i].faceCentres();
        const label nStartFaceIndex = patches[i].start();
        forAll(patchi, j)
            const labelList& facePoints = patchi[j];
            //const vector& Cf = Cfbc[j];
            //vector Sf = Sfbc[j];
            //Sf /= mag(Sf);
            label facei = nStartFaceIndex + j;
            // lambda already accounts for wallImpactDistance
            scalar lam = lambda(position_, endPosition, facei, stepFraction_);
            // check if trajectory is intersected by face
            if ( (lam <= 1.0) && (lam >= 0.0))
                // face intersects trajectory, now we need to check if the face hit
                // is withing the face
                vector pHit = position_ + lam*(endPosition - position_);
                forAll(facePoints, fi)
                    label fi1 = (fi + 1) % facePoints.size();
                    vector p1 = points[facePoints[fi1]];
                    vector p0 = points[facePoints[fi]];
                    vector edge = p1 - p0;
                    // check if position is within all edges...
matthi likes this.
Old   April 16, 2010, 03:00
Mihails Ščepanskis
Niklas, thank you. But I want to ask you to explain some places in your code to understand it:
myWallCheck.H
forAll(patches, i)
    //1) What does this check mean?
        //2) You don't use this variables further, do you?
        forAll(patchi, j)
            //Sf /= mag(Sf);
                //3) This is the vector of the coordinate of the point where the particle intersects the face, isn't it?
                    //4) Here I should check if pHit is in the face. But it will be
                    //within anyway, because we have checked that the
                    //particle intersects this face!
And general question. I am not sure that I understand your idea correct. So you suggest:
1) to remove the check that the distance between the cell center and face center is larger than wallImpactDistance in lambda function in ParticleI.H
2) to add this code in Particle.C
After this modification will been made, FOAM will check if the particle hit the wall anyway, but not only when the particle is in the boundary cell.
Have I understood your idea correct?
Mihails Ščepanskis
Old   April 16, 2010, 03:14
niklas's Avatar
Niklas Nordin
1. I thought that was obvious. It checks if the patch is a wall or not.
2. You will (probably ) need them later when you move the face centre point, to check if the face hit is
withing the face-edges
3. yes.
4. nope. the lambda calculation assumes that the face is infinite, since it only has a face centre point
and a face normal. I would suggest that you decompose the face into triangles using the face-center
and the points on the edges and then check if the face hit is within one of these triangles.
general.
1. yes.
2. yes.
and if the face is hit you need to append the face index to the faces-variable in the trackToFace-routine
Old   April 16, 2010, 07:33
Mihails Ščepanskis
I have written the code to check if pHit is within the edges of the face.
                scalar S = 0.0;
                    vector lHit1 = p1 - pHit;
                    vector lHit2 = p0 - pHit;
                    scalar S += mag(lHit1 ^ lHit2) / 2.0;
                if (S == mag(Sfbc))
                    //the face should be added to faces-variable
But I am not sure that I know how to add this face to faces. Is there any method to add the new face of thirst of all I should increase the size of the faces massive for 1 element and them fill this element this the new face?
Mihails Ščepanskis
Old   April 16, 2010, 07:50
niklas's Avatar
Niklas Nordin
faces.append(facei)
...I seriously doubt that check though.
I think you should come up with something else
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
Iclude particle diameter effect in wall? yueroo FLUENT 0 April 14, 2001 03:56
