Parallel Run problem
Old   April 1, 2010, 09:47
Default Parallel Run problem
shhe is on a distinguished road
I have a problem with running firefoam in parallel. Working with serial there is no problem. With parallel, I encountered a problem after writing two or three data set the program stopped and exit and give the following statments:
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/shhe/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/shhe/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 ??smoothSolver: Solving for Uz, Initial residual = 0.00703829, Final residual = 5.77079e-09, No Iterations 8
DILUPBiCG: Solving for ft, Initial residual = 0.00165804, Final residual = 4.86177e-10, No Iterations 3
max(ft) = 1
min(ft) = -3.744e-09
in "/lib64/libc.so.6"
#3 Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int)max(ftVar) = 0.0341966
min(ftVar) = 1.3266e-128
#4 Foam::GaussSeidelSmoother::smooth(Foam::Field<doub le>&, Foam::Field<double> const&, unsigned char, int) const in "/home/shhe/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) constDILUPBiCG: Solving for ft, Initial residual = 0.00185502, Final residual = 9.89006e-10, No Iterations 3
max(ft) = 1
min(ft) = -4.84243e-07
#6 GAMG: Solving for pd, Initial residual = 0.0173815, Final residual = 6.79687e-09, No Iterations 13
max(ftVar) = 0.0340001
min(ftVar) = 9.06034e-141
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
Foam::fvMatrix<Foam::Vector<double> >::solve(Foam::dictionary const&)time step continuity errors : sum local = 1.79503e-11, global = -8.99262e-13, cumulative = 0.000116242
in "/home/shhe/OpenFOAM/shhe-1.6/applications/bin/linux64GccDPOpt/fireFoam"
#7 smoothSolver: Solving for k, Initial residual = 0.00373242, Final residual = 4.77105e-09, No Iterations 6
mainExecutionTime = 1301.07 s ClockTime = 1311 s
#8 __libc_start_mainCourant Number mean: 0.0316383 max: 0.505215
deltaT = 0.00146301
Time = 0.185297
#9 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) constDILUPBiCG: Solving for ft, Initial residual = 0.00166794, Final residual = 4.49196e-10, No Iterations 3
max(ft) = 1
min(ft) = -5.56997e-09
max(ftVar) = 0.0345528
min(ftVar) = 9.88153e-128
19253 (n1) exited due to signal 8
The following is my controlDict:
application fireFoam;
startFrom startTime;
startTime 0;
stopAt endTime;
endTime 20.0;
deltaT 1e-5;
//writeControl adjustableRunTime;
writeControl runTime;
writeInterval 0.1;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression uncompressed;
timeFormat general;
timePrecision 6;
graphFormat raw;
runTimeModifiable yes;
adjustTimeStep yes;
maxCo 0.5;
maxDeltaT 0.01;
and decomposeParDict:
numberOfSubdomains 8;
method simple;
//method metis;
//method scotch;
simpleCoeffs
n (2 2 2);
delta 0.001;
hierarchicalCoeffs
n (1 1 1);
delta 0.001;
order xyz;
scotchCoeffs
processorWeights
1
1
1
1
1
1
1
1
manualCoeffs
dataFile "";
distributed no;
roots
"<root0>"
"<root1>"
"<root2>"
"<root3>"
"<root4>"
"<root5>"
"<root6>"
"<root7>"
shhe is offline   Reply With Quote
Old   April 27, 2010, 06:52
Francois Gallard
fgal is on a distinguished road
Your Courant number is of 0.5, I noticed that above 0.45, with most of the schemes I used, fireFoam diverges due to numerical instability. Could you try to reduce your time step by setting the maxCo entry to 0.3 in controlDict ?
Francois
fgal is offline   Reply With Quote
Cannot run Star-CCM+ parallel in Linux dburns Siemens 9 April 27, 2010 12:01
Problem with Fluent Parallel DarrenC ANSYS 0 October 27, 2009 05:38
nonNewtonianIcoFoam - problem with parallel run chris_sev OpenFOAM Bugs 4 April 1, 2009 09:13
Parallel run with engineFoam francesco OpenFOAM Bugs 1 November 25, 2008 07:06
Problem on Parallel Run Setup Hamidur Rahman CFX 0 September 23, 2007 17:11
