SimpleFoam Error with librdmacm amp libibverbs
Old   July 17, 2008, 17:21
Default Hi all, I am trying to run
dnomdec is on a distinguished road
Hi all,
I am trying to run simpleFoam (1.4.1) in parallel. When I ran in double precision, things seem to work OK. However, in single precision, I got the following error (on each processor I am running):
librdmacm: couldn't read ABI version.
librdmacm: assuming: 4
libibverbs: Fatal: couldn't read uverbs ABI version.
CMA: unable to open /dev/infiniband/rdma_cm
[0,1,0]: OpenIB on host hpcs01 was unable to find any HCAs.
Another transport will be used instead, although this may result in lower performance.
Does simpleFoam require different/extra libraries in single precision vs. double precision? I could find librdmacm.so, libibverbs.so and libmthca.so in /usr/lib. The funny thing is, I don't even have infiniband on my cluster.
I'm quite new to OpenFOAM, so any help is appreciated.
Thx!!
Ned
dnomdec is offline   Reply With Quote
Old   May 21, 2010, 08:02
Default Check the OFED version
sid
sidharth is on a distinguished road
I had the same error.
The problem was due to the mismatch in OFED version and the kernel version.
Install the latest version of OFED and check if it supports the kernel version that you are using.
It worked for me.
All The Best!!!
Sidharth Kashyap
sidharth is offline   Reply With Quote
SimpleFoam error sven82 OpenFOAM Running, Solving & CFD 0 October 16, 2008 04:13
Error running simpleFoam in parallel skabilan OpenFOAM Running, Solving & CFD 2 August 29, 2008 09:42
SIMPLEFOAM ERROR ON A RAE2822 dinonettis OpenFOAM Running, Solving & CFD 0 April 28, 2008 09:50
Error message using simpleFoam plmauk OpenFOAM Running, Solving & CFD 0 January 22, 2008 07:46
SimpleFoam error message braennstroem OpenFOAM Running, Solving & CFD 1 October 15, 2007 12:33
