convergence check implemented in OF-1.6.x
Old   May 31, 2010, 09:04
Default convergence check implemented in OF-1.6.x
vaina74 is on a distinguished road
I use simpleFoam for hydrodynamic cases (external flow). I read here that convergence check has been implemented. Please, can anyone explain how to use it? I'd like to stop the solving process when convergence criterion is satisfied. What are the appropriate criteria for my case? I can't find any suggestion in the forum.
vaina74 is offline   Reply With Quote
Old   May 31, 2010, 09:59
Cedric Van Holsbeke
CedricVH is on a distinguished road
Just set a value for convergenceCriterion in the subdictionary SIMPLE of your fvSolution file, for example 1e-3 or 1e-5.
CedricVH is offline   Reply With Quote
Old   May 31, 2010, 10:37
Sorry, it's not enough for me. I don't know or understand the syntax of the code lines (and where have i put them?) to check convergence. I need just an example, is something like
SIMPLE
    nNonOrthogonalCorrectors 0;
    convergenceCriterion 1e-5
in fvSolution?
Old   May 31, 2010, 10:41
Cedric Van Holsbeke
Indeed, you are correct. Just put a semicolon behind the value:
SIMPLE
    convergenceCriterion 1e-5;
Old   May 31, 2010, 10:45
You're right, I was absent-minded. Thank you, I'm going to test that.
Old   June 3, 2010, 08:35
I included in fvSolution
SIMPLE
but I think simpleFoam made 1000 iterations with no convergences check:
smoothSolver:  Solving for Ux, Initial residual = 1.39053e-08, Final residual = 6.56736e-09, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 1.21505e-08, Final residual = 5.93553e-09, No Iterations 1
smoothSolver:  Solving for Uz, Initial residual = 2.05638e-08, Final residual = 9.82093e-09, No Iterations 1
GAMG:  Solving for p, Initial residual = 9.89818e-08, Final residual = 9.89818e-08, No Iterations 0
time step continuity errors : sum local = 5.09515e-08, global = -3.38207e-11, cumulative = 0.00191433
smoothSolver:  Solving for omega, Initial residual = 9.20253e-09, Final residual = 9.20253e-09, No Iterations 0
smoothSolver:  Solving for k, Initial residual = 9.94271e-09, Final residual = 9.94271e-09, No Iterations 0
ExecutionTime = 19135.6 s  ClockTime = 19607 s
What's the problem?
convergence for transient/steady state simulation Gab CFX 36 August 20, 2012 12:55
Problem with Convergence!! Elleana FLUENT 8 February 28, 2008 01:44
convergence parameters amv Phoenics 4 September 21, 2005 06:49
Convergence tips John CFX 3 August 28, 2005 01:15
Slow convergence Jesper CFX 1 July 7, 2004 16:59
