ElectrostaticFoam problemerror
Old   October 6, 2007, 18:09
Default Hello, I am trying to use Ope
Sjaak Verdoold
sverdoold is on a distinguished road
I am trying to use OpenFoam to determine the electric field which then is to be used in some other code. After quite some hassle I got things to work at least slightly (although I still have major problems exporting/extracting the electric field values).
I am pretty new to Foam, but when I took a closer look at the electrostaticFoam source I got the impression that the electric field (rhoFlux in the solver) is a surfaceScalarField, so if I am correct consists of scalar values at the surfaces of the mesh cells. However, I think an electric field is always directed and should therefore be a surfaceVectorField or so. Is this correct or am I missing a crucial point here?
I tried to change this, but in that process could not get the code to compile anymore due to problems with the various operators and the new type of rhoFlux.
Does anyone have comments, ideas, suggestions or anything else about this?
Any help would be greatly appreciated!
Sjaak
sverdoold is offline   Reply With Quote
Old   October 7, 2007, 15:17
Default It's the same as with the regu
Assistant Moderator
Bernhard Gschaider
It's the same as with the regular phi (see discussions elsewhere): if you multiply it with the face-normal you get your vector value.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   June 21, 2010, 18:22
Xingzhi You
masspec is on a distinguished road
Hi! Do you happened to know what does the following code in ElectrostaticFOAM does?
solve(fvm:: ddt(rho)+ fvm :: div (rhoFlux, rho) ) I do not
understand what does this do? It does not look like a continuity
equation for the charge conservation. And also rhoFlux should be a
surface vector field, and rho is a volume field, how could them be mixed
together for calculation?
masspec is offline   Reply With Quote
What is the k in electrostaticFoam waynezw0618 OpenFOAM Running, Solving & CFD 2 January 18, 2019 20:44
Sampling rhoFlux in electrostaticFoam sverdoold OpenFOAM Post-Processing 14 November 16, 2010 16:19
What is the k in electrostaticFoam waynezw0618 OpenFOAM Running, Solving & CFD 0 February 1, 2009 10:21
