Atmospheric boundary layer
Like Tree7Likes
Old   June 13, 2010, 06:55
Default Atmospheric boundary layer
Daniele
Daniele111 is on a distinguished road
Hi
I try to simulate an atmospheric boundary layer, on bottom I use wall function, but if i use nutRoughWallFunction, epsilon has a overshooting in last cells why?
Best Regards
Daniele111 is offline   Reply With Quote
Old   June 14, 2010, 05:57
Michael
farbfilm is on a distinguished road
the overshooting is a known problem! Look for example here:
http://www.openfoamworkshop.org/2009...ner_slides.pdf
What Version of OpenFOAM are you using? I think, there have been some problems with the nutRoughWall-Condition in OpenFOAM 1.6! So, you should use OpenFOAM 1.6.x!!
Hope, that helps!
farbfilm is offline   Reply With Quote
Old   June 14, 2010, 06:05
Daniele
Hi
I read this paper, useful. But the problem is openfoam 1.6! I use now wall function of 1.6.x and I haven't overshooting problem,thanks you
Old   June 14, 2010, 11:58
Daniele
using openfoam 1.6.x the overshooting there isn't; but I Have another problem: in atmospheric boundary layer simulation, th wall value of epsilon and k would be costant? In my simulation these value are constant only after some cells along x axis Why?
Old   June 15, 2010, 05:04
Daniele
Hi
What are the correct boundary conditions for p field in these simulation?
Thanks
Old   June 15, 2010, 05:05
Michael
What is x?? Is it the height of your domain or the main flow direction??
Old   June 15, 2010, 05:13
Daniele
Main flow direction, change inlet p condition:
Old   June 15, 2010, 05:29
Michael
Sorry, I don't understand what Wss means...
I've chosen a "zeroGradient"-condition for my ABL-Simulations at the inlet for p!
To achieve a homogenous ABL (constant values in flow direction), you have to calculate the right Ks (and Cs) in subject to your z0 (conversion of z0 to Ks due to your roughWallBC)!
Hope, that helps...
Old   June 15, 2010, 05:32
Daniele
Wss, is wall shear stress, my z0 is 0.001, Ks=0.02, Cs=0.5 it's wrong?
Thanks you!
Old   June 15, 2010, 05:36
Daniele
My Bc. Thanks you again
Old   June 15, 2010, 05:42
Michael
I'm getting a value of 0.019586! Almost the same...
I've used the formula:
Ks = E*z0/Cs where E=9.793 is a constant of the wall function!
Old   June 15, 2010, 05:47
Daniele
My Ks=20*y0, but where is th mistake? Your Cs=0.5? E in your simulation epsilon, k are constant in the first cell along main flow direction, my x-axis?
Old   June 15, 2010, 05:52
Michael
I think, the velocity at the bottom should be zero (no slip condition)!
Unfortunately, I don't have any experiences with the timeVaryingMappedFixedValue-BC! So, I can't help with this! I used the GroovyBC for the analytical profiles!
Maybe, you should define the constants of the wall function in the nut-file! Just to be sure, you use the same like in your conversion from z0 to Ks! Actually, Cs is 0.327 in your BC's and not 0.5 like you mentioned before!
Old   June 15, 2010, 06:01
Daniele
I just use groovyBc, timeVaryingMappedFixedValue-BC is not the problem, it's the same thing. I don't understand when you say that I would define the constants of the wall function in the nut-file. What do i do this? The velocity at the bottom has a value becouse I use like reference a paper that imposed it, but I pose it 0 and the problem there is. The p bc is the same that you have?
Old   June 15, 2010, 06:48
Michael
Yes, p BC is the same!!
Old   June 15, 2010, 15:02
Daniele
Hi
Bah I try to use absurd values of Ks and Cs, but the result is always the same; I copied the turbulenceModels folder of OpenFOAM 1.6.x and I copy it in src folder of OpenFOAM 1.6 and the I compile it. It's wrong? Because if I change ks and cs not change the result?
Old   June 15, 2010, 16:01
Daniele
Can i see your bc?
Old   June 15, 2010, 17:36
Michael
sure! Here are my BC's! I definitely get a change when I use different values for Ks (see the picture)!
Hope that helps! Why do you want to simulate an ABL? What is the topic of your project??
Old   June 15, 2010, 17:53
Daniele
Thank you! I must simulate sand dune evolution. So I would calculate shear stress at bottom. Thank you again
What are these fields in your groovy bc?
refValue uniform 0;
refGradient uniform 0;
valueFraction uniform 1;
value uniform 0.1;
valueExpression "para";
gradientExpression "0";
fractionExpression "1";
Old   June 16, 2010, 05:08
Daniele
I try to use your bc setup, but the velocity field along main flow is these. It's correct? What is your first cell higth? My domain is higth 100m
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Turbulent Boundary Layer on a Flat Plate Hoshang Garda FLUENT 1 November 27, 2013 10:24
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
Combining BCs: wall - outlet. Boundary layer disappears MartinaF OpenFOAM Running, Solving & CFD 1 July 20, 2009 18:14
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
