How to use the CICSAM scheme
Like Tree1Likes
  • 1 Post By henry
Old   April 14, 2005, 00:21
Default I want to use CICSAM scheme in
Luckyluke
luckyluke is on a distinguished road
I want to use CICSAM scheme in the VOF solver 'interFoam' for interfacial flow. What kind of rules should be obdyed? Is there any difference between CICSAM and the other schemes?
Please show me a eexample.
Thank all.
luckyluke is offline   Reply With Quote
Old   April 14, 2005, 21:23
Default CICSAM has been taken out of t
Hrvoje Jasak
CICSAM has been taken out of the standard release, together with the free surface solver that uses it (superceded with the new stuff). I've got a copy of it knocking about somewhere but it will take time to dig it out and return it to life...
Hrv
Hrvoje Jasak
Old   April 14, 2005, 22:31
Default Thank you. Then what is the di
Luckyluke
Thank you. Then what is the difference between the new stuff and the CICSAM? The new stuff is more appropriate for interfacial flow?
Old   April 15, 2005, 04:14
Default The difference between Onno's
henry is on a distinguished road
The difference between Onno's CICSAM scheme and my new approch has already been debated at length on this discussion site, you will probably find what you need by searching back through old threads and postings.
duckfly likes this.
henry is offline   Reply With Quote
Old   April 18, 2005, 01:55
Default Where can I find some referenc
Luckyluke
Where can I find some references about the new interface solver 'InterFOam'?
Old   July 8, 2010, 09:42
Default corrector procedure
Ren/Xingyue
hilllike is on a distinguished road
I am just a beginner of CICSAM scheme.
And there is one problem that si confusing me.
In the corrector procedure,weighting factors is modified using one demensional case,actually,in two demensional case,one D cell havs two A cells.So how to treat this problem,FA-E-/2?
hilllike is offline   Reply With Quote
AUSM scheme ? Central Scheme boling Main CFD Forum 7 January 7, 2016 02:41
scheme help wilson FLUENT 0 January 16, 2006 13:27
Help!explicit multistage scheme with upwind scheme D .T. Main CFD Forum 1 June 4, 2003 03:42
what shall I do after get F(i+1/2) in Roe scheme? rrt willow Main CFD Forum 2 October 18, 2002 22:56
roe scheme Jian Xia Main CFD Forum 7 August 9, 2000 01:18
