Free fall body simulation
Old   March 12, 2009, 06:39
Default Hi I am trying to simulate
Velan
velan is on a distinguished road
Hi
I am trying to simulate free fall object(example airfoil). As airfoil falls, it will deform in its shape. I have seen the tutorial of icoFsiFoam and icoDyMFoam. icoFsiFoam solves both fluid and solid but not movingmesh (have doubt)like icoDyMFoam. Which openFoam solver will handle to solve fluid, solid flows and also movingmesh ?
Thanks
Velan
velan is offline   Reply With Quote
Old   March 12, 2009, 07:15
Default Hi Hey 50% got hope for my
Velan
Hi
Hey 50% got hope for my problem .
I have seen the body deformation and dynamicmesh using icoFsiFoam. But object is not falling down. For example i dont know how to apply gravity using icoFsiFoam. Will icoFsiFoam solve this problem ?
Thanks
Velan
Old   March 12, 2009, 09:10
Default Hi all I solved the simulat
Velan
Hi all
I solved the simulation using icoFsiFoam without body falling. When i tried to apply dynamic/moving (for falling object)mesh property, i got the following error.
mu = 769.231 Pa
lambda = 659.341 Pa
Reading coupling properties
request for fvMesh motionSubset from objectRegistry fluid failed
available objects of type fvMesh are
2
solid
region0
From function objectRegistry::lookupObject<type>(const word&) const
in file /home/tetra/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/objectRegistryTempl ates.C at line 142.
FOAM aborting
Aborted
I have attached my case directory. i tried to solve it but i dont know where i am doing wrong. Can someone find me the bug on it
regards
- Velan
Old   March 12, 2009, 09:16
Default Here is the file /attach{}
Velan
Here is the file
/attach{}
Old   March 12, 2009, 10:08
Default You can download the file from
Velan
You can download the file from the below link
http://homepages.iitb.ac.in/~siva.d/fsi.tgz
Sorry for posting many posts.
Old   July 31, 2010, 13:23
Default No deforamtion
mmahdinia is on a distinguished road
Hi, Sorry for the bothering,
But do you know how one can solve for a rigid sphere in a body of water?
Yours sincerely,
Mani Mahdinia
mmahdinia is offline   Reply With Quote
Free Body Dynamics jason OpenFOAM Running, Solving & CFD 7 January 23, 2008 07:32
Free surface and moving body Steve Siemens 4 August 20, 2004 11:06
Free surface and moving body Steve FLUENT 0 August 18, 2004 02:54
velocity of a body fall. th. viscous medium sohrab arora Main CFD Forum 3 September 11, 2001 22:33
Flow field around a ball that doing free fall in a cube Nadomic Lee Main CFD Forum 3 September 15, 1999 14:55
