twoPhaseEulerFoam not working with turbulence
Old   April 15, 2009, 02:09
Default twoPhaseEulerFoam not working with turbulence
Aditya
aditya_sin is on a distinguished road
Hi all,
I am not able to run twoPhaseEulerFoam with turbulence. However without turbulence it is working fine. I am running a bubble column case with freeboard at the top of the water column.
Can anyone help?
aditya_sin is offline   Reply With Quote
Old   April 15, 2009, 09:17
Raghavendra
raagh77 is on a distinguished road
Send a message via Yahoo to raagh77 Send a message via Skype™ to raagh77
Hi..
even I am trying the same case with free surface. I was able to run with turbulence being "ON" with some changes
. including relaxation factors.
. increasing number of correctors PISO to 8 in fvSolution
The simulation was quite stable but time accurate predictions was not that good..(I mean I got the a bit higher time period what the experiments says)
and also this might (Alberto suggestions) help you
http://www.cfd-online.com/Forums/ope...ditions-2.html
raagh77 is offline   Reply With Quote
Old   April 15, 2009, 22:09
Aditya
Hi Raghavendra,
Thanks for your suggestions.
I tried increasing the PISO correctors to 10 and reducing the timestep by two order of magnitude but still the simulation is crashing. I also tried underrelaxing but that does not work too.
Can you tell me what were the turbulence boundary conditions you were using?
Also I would appreciate any other suggestions you may have.
Old   April 18, 2009, 17:19
Raghavendra
what is your inlet velocity?
based on the inlet velocity calculate k and epsilon ..boundary conditions are epsilon and k
dimensions [0 2 -3 0 0 0 0];
internalField uniform 1e-06;
boundaryField
wall
type zeroGradient;
frontwall
type zeroGradient;
backwall
type zeroGradient;
sidewalls
type zeroGradient;
outlet
type zeroGradient;
inlet
type fixedValue;
value uniform 1e-6;
and for K
dimensions [0 2 -2 0 0 0 0];
boundaryField
wall
type zeroGradient;
frontwall
type zeroGradient;
backwall
type zeroGradient;
sidewalls
type zeroGradient;
outlet
type zeroGradient;
inlet
type fixedValue;
value uniform 1e-06;
Old   April 18, 2009, 17:24
Raghavendra
As suggested by my supervisors I tried running the simulation with turbulence being on
from the flow field developed by laminar flow..
Probably this might work.
In my case the simulation was quite stable and results were also quite satisfactory only for velocity profiles (as it is in the experiments)
but the oscillation frequency of the plume developed didn't match.
Old   August 3, 2010, 09:47
Irin Sun
irinsun is on a distinguished road
in the case turbulence on why shouldn't we use
kqRwallfunction and epsilonWallFunction as the boundary condition on the wall?
irinsun is offline   Reply With Quote
turbulence model
Question on Turbulence Intensity Eric FLUENT 1 March 7, 2012 04:30
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
Code release: Flow Transition and Turbulence Chaoqun Liu Main CFD Forum 0 September 26, 2008 17:15
TwoPhaseEulerFoam and turbulence hemph OpenFOAM Bugs 0 January 29, 2007 05:18
