August 4, 2010, 00:22 |
Pressure Velocity coupling problem
Sunho Park
Hello Foamers,
I try to run a cavitation problem using interPhaseChangeFoam. Before try to run a Foam, I tested a free stream flow without a objet and cavitation. (left/top: fixedValue velocity, right: fixedValue pressure (others are zeroGradient), bottom: symmetryPlane) However, a velocity at the 1st mesh neighbour the inlet boundary is drop and then recover a velocity. So, the pressure in inlet boundary is increasing a lot. do you know why these kind problem is happen? |
Pressure farfield vs Velocity Inlet BC | DarrenC | FLUENT | 1 | September 16, 2009 02:23 |
zeroGradient pressure and moving mesh | kassiotis | OpenFOAM Running, Solving & CFD | 0 | July 22, 2009 09:28 |
pressure with velocity inlet boundary conditions | Ashraf Sharara | FLUENT | 1 | August 21, 2008 07:29 |
a problem in calculating pressure drop in Fluent? | yu chun | FLUENT | 1 | May 18, 2004 03:40 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
