Error or Different Meaning of alpha in eEqu and hEqu of compressible solver?
Old   July 20, 2010, 11:56
Default Error or Different Meaning of alpha in eEqu and hEqu of compressible solver?
yu
universez is on a distinguished road
In compressible flow solvers, eEqu and hEqu share the same parameter "thermal diffusivity", or turbulence->alphaEff() in the following equations. However, my understanding of the meaning of thermal diffusivity should be different in these equaitons, i.e. , (for a laminar flow),
In eEqu, alpha = K / (Cv rho), where Cv, k and rho are heat capacity at constant volume, theremal conductivity and density, respectively.
while, in hEqu, alpha = k / ( Cp rho), where Cp, k and rho are heat capacity at constant pressure, theremal conductivity and density, respectively.
My questions are:
1, my understanding about alpha is right or wrong?
2, if i am right, is openFoam wrong ?, or there is specific application inside openfoam dealing with this issue?
In sonicFoam eEqu is
solve
fvm::ddt(rho, e)
+ fvm::div(phi, e)
- fvm::laplacian(turbulence->alphaEff(), e)
- p*fvc::div(phi/fvc::interpolate(rho))
In rhoPisoFoam hEqu is
fvScalarMatrix hEqn
fvm::ddt(rho, h)
+ fvm::div(phi, h)
- fvm::laplacian(turbulence->alphaEff(), h)
DpDt
universez is offline   Reply With Quote
Old   August 8, 2010, 11:51
Thumbs up compare with rhoFurbFoam
kiran Ambilpur
kiran is on a distinguished road
Send a message via Skype™ to kiran
Hi yu
you are not wrong in understanding but you have compare similar solvers like rhoTurbFoam in 1.5 and sonicFoam in 1.6.
iam working on both the slovers and i feel both are same (Unsteady Turbulent compressible solvers).
try to analyze with rhoTurbFoam that will clear your doubt.
kiran is offline   Reply With Quote
