Dynamic Mesh Problem
Old   August 14, 2010, 16:28
Default Dynamic Mesh Problem
Daniel
dancfd is on a distinguished road
Hello all,
I am attempting to oscillate an airfoil and flap using angularOscillatingDisplacement, however I receive the following errors:
Create time
Create mesh for time = 0
Selecting dynamicFvMesh dynamicMotionSolverFvMesh
Selecting motion solver: displacementLaplacian
PointPatchField<Type>::New(const pointPatch&, const Field<Type>&, const dictionary&) : constructing pointPatchField<Type>
PointPatchField<Type>::New(const word&, const pointPatch&, const Field<Type>&) : constructing pointPatchField<Type>
Selecting motion diffusion: quadratic
Selecting motion diffusion: inverseDistance
Time = 0.05
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam170/lib/linux64GccDPOpt/libOpenFOAM.so"
#1  Foam::sigFpe::sigFpeHandler(int) in "/opt/openfoam170/lib/linux64GccDPOpt/libOpenFOAM.so"
#2   in "/lib/libc.so.6"
#3  Foam::divide(Foam::Field<double>&, double const&, Foam::UList<double> const&) in "/opt/openfoam170/lib/linux64GccDPOpt/libOpenFOAM.so"
#4  Foam::operator/(double const&, Foam::tmp<Foam::Field<double> > const&) in "/opt/openfoam170/lib/linux64GccDPOpt/libOpenFOAM.so"
#5  Foam::fvPatch::makeDeltaCoeffs(Foam::Field<double>&) const in "/opt/openfoam170/lib/linux64GccDPOpt/libfiniteVolume.so"
#6  Foam::surfaceInterpolation::makeDeltaCoeffs() const in "/opt/openfoam170/lib/linux64GccDPOpt/libfiniteVolume.so"
#7  Foam::surfaceInterpolation::deltaCoeffs() const in "/opt/openfoam170/lib/linux64GccDPOpt/libfiniteVolume.so"
#8  Foam::fv::uncorrectedSnGrad<Foam::Vector<double> >::deltaCoeffs(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) const in "/opt/openfoam170/lib/linux64GccDPOpt/libfiniteVolume.so"
#9  Foam::fv::gaussLaplacianScheme<Foam::Vector<double>, double>::fvmLaplacianUncorrected(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) in "/opt/openfoam170/lib/linux64GccDPOpt/libfiniteVolume.so"
#10  Foam::fv::gaussLaplacianScheme<Foam::Vector<double>, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) in "/opt/openfoam170/lib/linux64GccDPOpt/libfiniteVolume.so"
#11  Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > > Foam::fvm::laplacian<Foam::Vector<double>, double>(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&, Foam::word const&) in "/opt/openfoam170/lib/linux64GccDPOpt/libfvMotionSolvers.so"
#12  Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > > Foam::fvm::laplacian<Foam::Vector<double>, double>(Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&, Foam::word const&) in "/opt/openfoam170/lib/linux64GccDPOpt/libfvMotionSolvers.so"
#13  Foam::displacementLaplacianFvMotionSolver::solve() in "/opt/openfoam170/lib/linux64GccDPOpt/libfvMotionSolvers.so"
#14  Foam::motionSolver::newPoints() in "/opt/openfoam170/lib/linux64GccDPOpt/libdynamicMesh.so"
#15  Foam::dynamicMotionSolverFvMesh::update() in "/opt/openfoam170/lib/linux64GccDPOpt/libdynamicFvMesh.so"
#16
 in "/opt/openfoam170/applications/bin/linux64GccDPOpt/moveDynamicMesh"
#17  __libc_start_main in "/lib/libc.so.6"
#18
Floating point exception
I find this very strange since I was able to run a very similar mesh, without the flap, using all the same files except for the blockMesh (new Dict) and /0/** (added the patch for the flap) files. The first case runs just fine, the second case will not run at all. I would appreciate any advice, since I cannot interpret these errors.
Thank you,
Dan
dancfd is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
Dynamic mesh update problem. David FLUENT 3 March 15, 2012 05:02
Dynamic Mesh problem Paul_321 FLUENT 11 August 11, 2009 11:32
CFD-3D flow problem using Dynamic mesh method. Sar_mech FLUENT 1 November 27, 2008 21:17
Dynamic mesh problem Sampath FLUENT 1 October 13, 2004 06:44
