trouble with `pressureDirectedInletVelocity'
Old   October 6, 2009, 03:38
Question trouble with `pressureDirectedInletVelocity'
Yohey Ishizu
yohey is on a distinguished road
Hi.
I'm using OpenFOAM-1.6.x on Ubuntu 8.04 and in trouble with `pressureDirectedInletVelocity' boundary.
I'm working on the attached case. This case contains direction-fixed boundary as
inletDirection uniform (1 1 0);
But, with this condition, the velocity in the mesh next to boundary is dobuled.
This is because of `operator=' in `pressureDirectedInletVelocityFvPatchVectorField.C '.
fvPatchField<vector>::operator=(inletDir_*(inletDi r_ & pvf));
So, I modified the `inletDirection' as (1/sqrt(2) 1/sqrt(2) 0).
inletDirection uniform (0.707107 0.707107 0);
This worked correctly.
(1) Next, I tried with more precise value.
inletDirection uniform (0.70710678 0.70710678 0);
But, calculation fails with this boundary.
(2) Actually this problem is derived from `pressureDirectedInletVelocityFvPatchVectorField.C '. So, I modified such sentence in this file as
fvPatchField<vector>::operator=(inletDir_*(inletDi r_ & pvf)/magSqr(inletDir_));
This modification also crashes calculation.
I can't understand these behavior of (1) and (2).
Would anyone help me to find the cause of these problems?
Sincerely.
Yohey
yohey is offline   Reply With Quote
Old   August 10, 2011, 11:42
Ali Q Raeini
aliqasemi is on a distinguished road
Yohey[/QUOTE]
Originally Posted by yohey View Post
Hi.
Yohey
This is because some of the faces in the patch are normal to the vector you specified for inletDirection, which causes a division by zero in the file pressureDirectedInletOutletVelocityFvPatchVectorFi eld.C. Changing the code or the value for inletDirection should fix the problem. I had the same problem using using OF.1.7.1, nearly two years later.
aliqasemi is offline   Reply With Quote
Old   October 4, 2013, 11:15
Smile Inlet Angle
Akash Sharma
akashjangid is on a distinguished road
Hello
I am doing simulation on a rotor blade.
Does anyone know how to give the inlet angle like this (which depends on z and y)
dir_cos1 = 4.04
dir_cos2 = EXPR{57.2958*(acos(0.07045*(z/sqrt(z*z+y*y))))}
dir_cos3 = EXPR{57.2958*(acos(-0.07045*(y/sqrt(z*z+y*y))))}
Thanks !!
akashjangid is offline   Reply With Quote
boundary condition, inlet
[GAMBIT] Trouble meshing complex VOF geometry RPJones ANSYS Meshing & Geometry 2 February 14, 2011 18:54
Finned Pipe Trouble fabioxyz CFX 8 August 31, 2009 02:20
Trouble in Gambit Tom FLUENT 8 July 23, 2002 09:17
equivalencing trouble Steve Collie CFX 6 August 22, 2001 18:26
trouble with fluxsum Jordi Siemens 2 September 29, 2000 03:57
