Turbulence Modelling (y+ etc.)
Old   September 8, 2010, 09:41
Default Turbulence Modelling (y+ etc.)
Michel
Michel_HB is on a distinguished road
Hello FOAMers,
I am doing some work on turbulent channel flow. Reynoldssnumbers are 3750 and 5000.
So, i guess, the standard k-epsilon-modell is not valid for such low Re-numbers.
Now I want to usw a lowRE-modell, i.e. LauderSharmaKE. Or would you suggest k-omega or k-omega-sst?
I read that I need a y+-value less <<1.
When I usw the yPlusRAS-Function I get the values, y_min and y_max and y_mean:
So whats the meaning of these parameters? and should be y_min and y_max less than 1??
Thanks in advance,
Michel
Michel_HB is offline   Reply With Quote
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
Turbulence modelling validation : Orifice flow Joe Main CFD Forum 2 July 26, 2006 16:41
Turbulence modelling Panos Siemens 6 July 8, 2004 02:40
Question about Low Re turbulence modelling. ghlee Main CFD Forum 1 May 28, 1999 19:29
