Can we restart the simulation from a different time in OpenFoam
Like Tree17Likes
Old   September 15, 2010, 22:57
Default Can we restart the simulation from a different time in OpenFoam
Vishal Nandigana
nandiganavishal is on a distinguished road
Dear Foamers,
I was running a simulation till a particular time period, but found that the steady state was not reached. I would like to know, whether I have to rerun my simulations again from the beginning or is it possible to start the simulations from the point where I stopped as the starting value. I was trying to implement this by changing the starting value in controlDict file, but couldnt be of any use. I would appreciate if you guys can throw your suggestions.
Thanks
Vishal
kon11 likes this.
nandiganavishal is offline   Reply With Quote
Old   September 15, 2010, 23:39
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Yes, it is possible use latestTime in stead of startTime in system/controDict. This info is available in User's Guide.
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   September 16, 2010, 00:44
Vishal Nandigana
Dear Santiago,
Thanks for the reply. I did change it in my control dict, but still get the same error.
My controlDict initial few lines
application eofFoam;
startFrom latestTime;
latestTime 3e6;
stopAt endTime;
endTime 6e6;
deltaT 200;
writeControl timeStep;
writeInterval 10000;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression uncompressed;
timeFormat general;
timePrecision 6;
runTimeModifiable yes;
Error message:
Create time
Create mesh for time = 3e+06
Reading field C1 (A)
compound has already been transfered from token
on line 39689 the empty compound of type List<scalar>#0 Foam::error:rintStack(Foam::Ostream&) in "/home/vishal/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/vishal/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Foam::token::transferCompoundToken() in "/home/vishal/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
#3 Foam::Istream& Foam:perator>><double>(Foam::Istream&, Foam::List<double>&) in "/home/vishal/OpenFOAM/vishal-1.5/applications/bin/linuxGccDPOpt/eofFoam"
#4 Foam::Field<double>::Field(Foam::word const&, Foam::dictionary const&, int) in "/home/vishal/OpenFOAM/vishal-1.5/applications/bin/linuxGccDPOpt/eofFoam"
#5 Foam::zeroIonFluxFvPatchScalarField::zeroIonFluxFv PatchScalarField(Foam::fvPatch const&, Foam:imensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/home/vishal/OpenFOAM/vishal-1.5/applications/bin/linuxGccDPOpt/eofFoam"
#6 Foam::fvPatchField<double>::adddictionaryConstruct orToTable<Foam::zeroIonFluxFvPatchScalarField>::Ne w(Foam::fvPatch const&, Foam:imensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/home/vishal/OpenFOAM/vishal-1.5/applications/bin/linuxGccDPOpt/eofFoam"
#7 Foam::fvPatchField<double>::New(Foam::fvPatch const&, Foam:imensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/home/vishal/OpenFOAM/vishal-1.5/applications/bin/linuxGccDPOpt/eofFoam"
#8 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::GeometricB oundaryField(Foam::fvBoundaryMesh const&, Foam:imensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/home/vishal/OpenFOAM/vishal-1.5/applications/bin/linuxGccDPOpt/eofFoam"
#9 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readField(Foam::Istream&) in "/home/vishal/OpenFOAM/vishal-1.5/applications/bin/linuxGccDPOpt/eofFoam"
#10 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) in "/home/vishal/OpenFOAM/vishal-1.5/applications/bin/linuxGccDPOpt/eofFoam"
#11 main in "/home/vishal/OpenFOAM/vishal-1.5/applications/bin/linuxGccDPOpt/eofFoam"
#12 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
#13 Foam::regIOobject::readIfModified() in "/home/vishal/OpenFOAM/vishal-1.5/applications/bin/linuxGccDPOpt/eofFoam"
From function token::transferCompoundToken()
in file lnInclude/token.C at line 96.
FOAM aborting
Aborted
Kindly let me know where I am making an error.
Regards
Vishal
Old   September 16, 2010, 02:31
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Originally Posted by nandiganavishal View Post
Dear Santiago,
latestTime 3e6;
stopAt endTime;
endTime 6e6;
With the entry
the latest time step available on the disk will be used.
Note that this is also the default if the keyword "startFrom" is missing.
With this option, you'd simply remove any later results, this will do what you want.
The entry
latestTime 3e6;
has no meaning and will be ignored.
Note, you could also use another alterative combination. For example,
startFrom startTime;
startTime 1000;
to specify that the calculation should start (or restart) from iteration 1000. However, I generally find it easier to remove the old results via the command-line and use the default startFrom latestTime.
Beyond that I'm not sure what other problem you are encountering.
olesen is offline   Reply With Quote
Old   September 18, 2010, 17:07
Vishal Nandigana
Dear Santiago
I did try your suggestion again but still get the same error. I would check with the tutorial codes and see if the cavity foam wrks or not. Further, I would like to know if I use probes function to calculate variation a variable with time, is it possible to start dumping the values from a particular start and stop time rather than from time t =0.
Kindly throw some light on this. I was searchin this in openFOAM tutorials and other forums but couldn't get any concrete answer.
Regards
Vishal
Old   September 20, 2010, 09:30
Bernhard Linseisen
Linse is on a distinguished road
I do not know if it is connected to your error message, but:
I did some restarts of different cases. If I restarted from the alst timestep, sometimes some data was missing. Usually everything went fine as soon as I used the last BUT ONE timestep as restarting step.
Perhaps it works if you try to restart from 2.99e6 or another value you still have stored inside the simulation folder?
Linse is offline   Reply With Quote
Old   September 20, 2010, 11:31
Vishal Nandigana
Thanks for the reply Linse, I would try that and would let you know!!
Old   October 10, 2010, 15:11
Vishal Nandigana
Dear Foamers,
I did try again to start the simulation from the latest time but still end up with the same error. I was able to run the cavity foam example and it was working fine for that case.
Here is a part of my controldict file
latestTime 100;
stopAt endTime;
endTime 200;
deltaT 100;
writeControl runTime;
writeInterval 100;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
timeFormat general;
timePrecision 6;
I notice that simulation is starting from 100 (initial time) and not from 200 (as deltaT is 100 and latest time is 100).
Here is the error message
Create time
Create mesh for time = 100
FOAM aborting
Kindly can anyone provide some help.
Thanks
Regards
Vishal Nandigana
Old   March 7, 2011, 16:34
anfho is on a distinguished road
notheless this thread is almost six months old, I wanted to add and clarify that if you are using OF1.7.x, it is not necessary to specify the latestTime per sae. If OF1.7.x is restarted and
is specified it will always start from the last solution written in the case folder (either at time 0 or at time latestTime).
My controlDict looks like this and is able to restart at any time:
application     fireFoam;
startTime       0.0;
stopAt           endTime;
endTime        10.0;
deltaT           0.001;
Regards, Andreas
uckmhnds and amber25 like this.
anfho is offline   Reply With Quote
Old   March 7, 2011, 16:57
Vishal Nandigana
Thanks Andreas. I was able to solve that issue..
Regards
Vishal
Old   March 9, 2011, 12:37
akidess's Avatar
Anton Kidess
It might help other people if you add a post providing details how you solved your problem.
HappyS5 likes this.
Old   March 9, 2011, 13:49
Ben K
benk is on a distinguished road
Is there an easy way to revert back to an old time during runtime (ie. while the solver is running)?
This way if my solver is becoming unstable due to a time step that is too large, I can go back to the last successful time and pick a smaller time step.
benk is offline   Reply With Quote
Old   March 9, 2011, 15:43
@Anton: I think I did that above.
@Ben: You would have to stop the solver iteration loop and then delete the unstable solutions in your directory and start with a different time step/ different settings from the time where you have a stable solution. This is definetely not possible while the solver is running.
Regards, Andreas
Old   March 9, 2011, 16:31
akidess's Avatar
Anton Kidess
@Ben: You would have to stop the solver iteration loop and then delete the unstable solutions in your directory and start with a different time step/ different settings from the time step where you have a stable solution. This is definetely not possible while the solver is running.
Regards, Andreas
The way I read Vishal's answer was that he solved the entire problem (he already had 'latestTime' included in his post from October 10). If that was not what he meant, you are right there was nothing to add.
Ben, I do believe that should be possible with some programming work. You have to access the Time object, then you can use either runTime.setTime() to set a specific time or runTime-- to go back one time step. Now, you'll have to make sure that old data is available, by calling setTime for a time you know you wrote data or storing the old time data like done in a SIMPLE style solver. Let me know if it works!
Doxygen for Time: http://foam.sourceforge.net/docs/cpp...14f547f414.php
Old   March 9, 2011, 17:18
Vishal Nandigana
Dear Foamers,
I did change the controlDict file from the latesttime step i had in my simulation for example
application coupleFoam;
startTime 18e6;
stopAt endTime;
endTime 25e6;
deltaT 100;
writeInterval 1e6;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
timeFormat general;
timePrecision 6;
The problem I was facing was that in the 18e6 folder some variables had non uniform values in the boundary condition that was not deducted by openfoam so I changed those non uniform values to uniform 0 (as once the iteration starts these values will be computed again)
Hope this helps
Regards
Vishal
uckmhnds likes this.
Old   March 10, 2011, 11:22
Ben K
I have something that kindof works:
if (trouble_flag == 1) {
// this will go back to the last good timestep
runTime.setTime( runTime.times()[runTime.times().size()-1].value(), runTime.times()[runTime.times().size()-1].value() );
// Now I have to read the values of the last good timestep...what's the best way to do this?
fieldName(IOobject("fieldName",runTime.timeName(),mesh,IOobject::MUST_READ,IOobject::AUTO_WRITE),mesh);
//read in all fields
//set a new dt
runTime.setDeltaT(someDeltaT);
//continue simulation
I think this works, but I have to manually read in the time directory fields, maybe I shouldn't be complaining about this but it just seems like a lot of unnecessary work.
I think having a feature like this could be very useful to OpenFOAM, I believe most commercial solvers can do this.
mm.abdollahzadeh likes this.
Old   March 14, 2011, 08:31
akidess's Avatar
Anton Kidess
Can you check if this works?
if (troubleflag == 1)
        instant oldtime = runTime.times()[runTime.times().size()];
        runTime.setTime( oldtime.value(), runTime.findClosestTimeIndex(runTime.times(), oldtime.value() ) );
        //set a new dt
        runTime.setDeltaT(runTime.deltaT().value() / 2.0);
        //runTime++ after include of setDeltaT should call objectRegistry::readModifiedObjects(), which in turn should update fields
PS. Didn't you already solve this problem in a different way last year? -> http://www.cfd-online.com/Forums/ope...tml#post262131
Old   July 22, 2014, 22:25
Default I restart the solution but this error appears
  #18
Hassan Adel
hassan1201 is on a distinguished road
Create time
Create dynamic mesh for time = 0.116
Selecting dynamicFvMesh dynamicMotionSolverFvMesh
--> FOAM FATAL IO ERROR:
patch 6 not empty type. Patch type = patch
file: /home/hassan/foam/foam-extend-3.1/tutorials/solidMechanics/icoFsiElasticNonLinULSolidFoam/HronTurekFsi/fluid/0.116/meshPhi::boundaryField::frontAndBackPlanes from line 41776 to line 41776.
From function emptyFvsPatchField<Type>::emptyFvsPatchField
const fvPatch& p,
const Field<Type>& field,
const dictionary& dict
in file fields/fvsPatchFields/constraint/empty/emptyFvsPatchField.C at line 100.
FOAM exiting
H.Elsheshtawy
hassan1201 is offline   Reply With Quote
Old   June 2, 2015, 14:11
Josh Elliott
jelliott121 is on a distinguished road
Is it possible to start from "t minus 1 timeStep"? With the server I am working with there is a possibility of being forced to shut down my process before completing the latestTime iteration. If that occurs, I want to be able to reboot and the solver should pick up from the last complete time step instead of the latest time step. purgeWrite set to 2, so the last complete iteration is left in the project directory. Any ideas how to start from this timeStep?
jelliott121 is offline   Reply With Quote
Old   November 30, 2015, 04:03
Default How to restart simulation in Ansys Fluent?
  #20
parham
mk091088 is on a distinguished road
Hi all,
I have the same question but in Ansys Fluent. My simulation had run for 3 days, unfortunately it was stopped for obscure reason, thus I have to re-run it again from the last time step. Any help would be appreciated.
mk091088 is offline   Reply With Quote
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
(chtMultiRegionFoam) reducing gravity increase the simulation time ! openfoam1 OpenFOAM 7 March 10, 2010 09:41
PostChannel maka OpenFOAM Post-Processing 5 July 22, 2009 09:15
influence of time step in insationary simulation Sascha Behrens FLUENT 0 December 1, 2005 09:08
