openfoam for heat transfer
Like Tree1Likes
Old   October 24, 2010, 08:54
maysmech's Avatar
maysmech is on a distinguished road
Originally Posted by Hasselhoff View Post
For windows I use heat flux boundaries. What kind of turbulence model are you using?
I use k-epsilon turbulence model.
Can you write things you enter in T file for windows (Type and Value) to define heat flux boundaries?
Best,
maysmech is offline   Reply With Quote
Old   October 24, 2010, 09:01
paka is on a distinguished road
Is it required to use one of the turbulence models as long as one only cares about general temperature distribution? Let's say I don't care much about eddies development, all I care about is just temperature distribution through the building structure. Is turbulence a key factor?
Just to speed up the process, I would try to simplify my simulation as much as possible, therefore skip turbulence.
Is it an acceptable, common procedure?
Thanks,
K
paka is offline   Reply With Quote
Old   October 24, 2010, 09:56
Hasselhoff is on a distinguished road
I will post my settings tomorrow, I don't have access to it now I was using the k omega SST for this one I think.
@ paka: if you chose to stay within the laminar setup, you don't need any turbulence model. Just chose the "laminar" model and switch turbulence to "off". It depends on your task if that makes sense. I wouldn't suggest it for a setup like the one above. There are some papers out there, discussing the adequate turbulence modeling for a given task..
Hasselhoff is offline   Reply With Quote
Old   October 24, 2010, 18:14
Yes, thank you, but my question was rather towards what is a general procedure, tendency in solving such problems, where one only cares how temperature spreads across the building?
I just don't really imagine why turbulence would play important role in HVAC. Can anyone enlighten me
Thanks!
K
Old   October 25, 2010, 04:46
In HVAC, we have low Reynolds numbers and high turbulence ratios (10-75%). Especially the turbulent normal stresses near walls and the transition effects at the inlets influence the flow.
Airflows underneath the ceiling feature certain phenomena like the “coanda effect” and the rearrangement of turbulent normal stresses which is in the end effecting the temperature distribution as well as the velocity. A laminar flow cannot consider these aspects, standard turbulence models also do not catch up completely..
“The user of a turbulence model is more like a test pilot.. [..]”
//Michael
Old   February 16, 2012, 04:56
MatejP is on a distinguished road
Originally Posted by maysmech View Post
Here is geometry of the problem.
It is a room with 6 inlet fans at ceiling with T=290K and U=0.1 m/s. A window with 305 K is shown and walls and door have zeroGradient temperature.
Good day!
I would like to make a case, where a room with 2 windows (inlet and outlet for ventilation) is defined. I would like to define this geometry in a stl file with some program (http://www.rhino3d.com/) but I don't know how to implement that window is a different patch than walls (different BC). Could this be done like in tutorials/mesh/snappyHexMesh/snappyMultiRegionHeater where there are more than 1 stl file each as a different patch? I don't want to try to solve my problem like in tutorials/mesh/snappyHexMesh/motorBike where inlet and outlet are defined in blockMeshDict and are not on stl defined geometry (motorbike).
I completed a few tutorials and modified one of them succesfully (stl file generated in Mathematica, meshed with sHM, result is below).
I was browsing this forum and found above quoted post and would politely ask, if it is possible, anyone could send me case files for this or similar ventilation problem. My e-mail: podergajs.matej@gmail.com
Thank you for any reply and sorry for posting so long arter the last post.
Matej Podergajs
MatejP is offline   Reply With Quote
Old   January 29, 2015, 02:01
Default chtregionsimpleFoam
  #27
sa har
sa har is on a distinguished road
hello,I started to leran openfoam.i have proplem when i work with chtregion simplefoam and i cant solve this error.
this error is:
Create time
--> FOAM FATAL IO ERROR:
keyword regions is undefined in dictionary "/home/sahar/Desktop/fasle4/constant/regionProperties"
file: /home/sahar/Desktop/fasle4/constant/regionProperties from line 18 to line 20.
From function dictionary::lookupEntry(const word&, bool, bool) const
in file db/dictionary/dictionary.C at line 402.
FOAM exiting
sahar@sahar-S451LB:~/Desktop/fasle4$
can you hlep me?how can solve this problem.
sa har is offline   Reply With Quote
Old   January 29, 2015, 21:41
Alex
zfaraday will become famous soon enough
Hello, and welcome to the forum!
First of all, as you said you just started learning OpenFOAM, please, take a look at this page URGENTLY to start getting inside chtMultiRegion cases. And please, read carefully THE WHOLE page and try to do EVERYTHING it's said to do. Once you have done it all, you can come back again to the forum to ask any doubt that may come out.
Flash forward Mode ON
Thank you, Alex. It's a very useful site and I learnt a lot about cht cases after reading it!
You're welcome!
Flash forward Mode OFF
this error is:
Create time
FOAM exiting
As I said, you have to learn a little more about OpenFOAM before asking about that. After you have studied the site I gave you above, maybe you can find it out on your own! Otherwise, I can help you!
TIP (as a newbie gift): This error says that you haven't defined the regions field within the constant/regionProperties dictionary or maybe you don't even have such dictionary within the constant directory. If you still don't know what I am talking about, please, work hard with the basic case you can find in the page I gave you.
Oooohhh! Thank you Alex, you are the best!
You are welcome, again!
Hope it is useful for you to start playing with OF and chtMultiRegion cases!
Regards,
Alex
Btw, this is a very old post, you could have posted it somewhere else or opened a new thread in order to get help.
Web site where I present my Master's Thesis: foamingtime.wordpress.com
The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in!
zfaraday is offline   Reply With Quote
Old   January 30, 2015, 01:26
sa har
You're welcome!
Regards,
Alex
thanks Alex,i try to understand and solve my problem with page that you said.
Old   February 12, 2015, 18:46
Juan David Rodriguez P
JuanRodriguez is on a distinguished road
The other problem is how can we define T B.C for windows.
I think fixedValue is not a good assumption for windows temperature.
Hi maysmech. I am trying to simulate a similar case to yours, i.e., with forced flow through fans. I am using buoyant BoussinesqSimpleFoam but always receive this error:
Continuity error cannot be removed by adjusting the outflow.
How did you set your inlet and outlet BC?
Thank you in advance.
JuanRodriguez is offline   Reply With Quote
Conductive Heat Transfer in OpenFoam? FloK OpenFOAM 8 March 18, 2011 13:51
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 05:56
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
