openfoam for heat transfer
Like Tree1Likes
Old   September 22, 2010, 16:14
Default openfoam for heat transfer
kirankarki is on a distinguished road
Hi everyone,
can anyone tell me if openfoam is capable to handle the heat transfer mechanism through building envelope ? since heat transfer in building should include solar radiation due to outdoor temp, weather that varies with time, conduction through different layers of materials, convection due to natural ventilation air etc that determines the inside temp and heat flux. Which solver is good for this or new solver is to be created myself?
Thanks
kirankarki is offline   Reply With Quote
Old   September 23, 2010, 11:29
Eugene de Villiers
eugene is on a distinguished road
You are pretty much in create new solver territory. To treat the wall heat transfer in a transient way, you pretty much have to do some form of conjugate heat transfer as well. If a steady approach to wall heat transfer is ok, then you just need to couple the inside and outside via a layer based resistance.
Let me know if you need a hand, I might have some appropriate code lying around.
eugene is offline   Reply With Quote
Old   September 23, 2010, 11:43
Default For heat transfer thru wall
Thanks eugene for response,
i m very new to this openfoam and i m construction management major thus no effecient background of programming ,i want to have transient heat transfer through wall and the outside weather data like temp, wind vel changes every hour, if u have some solvers for this case to send me, it will be highly appreciated, also i need to know how many kind of files should i create for system , constant and time directory ,
thanks again
Old   September 23, 2010, 19:02
Eugene de Villiers
Unfortunately I do not have a ready made solution for you.
There is a however a thermal boundary condition called "wallHeatTransfer" that couples an outside temperature to the inside wall via a fixed transfer coefficient. Unfortunately the BC has several limitations: 1 it wont help you with solar radiation, 2. it assume laminar flow on the inside.
You can use this T boundary in conjunction with the rhoSimpleFoam and other "compressible" solvers.
Good luck,
Old   September 24, 2010, 03:07
val46 is on a distinguished road
Hi eugene,
what do you mean by layer based resistance?
Is there a way to set a thermal resistance between 2 regions?
Regards,
Toni
val46 is offline   Reply With Quote
Old   September 24, 2010, 04:53
Eugene de Villiers
No, there is no way to currently set layer based resistance between two regions. It isn't that hard to implement if you only want a steady state solution though. If you want a transient solution in the solid, you will need some kind of mesh for the solid.
This is something I would like to to do at some point in the future. If I ever get round to it, I will let you know.
Old   September 24, 2010, 10:30
Peter Roosen
petroo is on a distinguished road
Maybe you might take a look at the EnergyPlus system that is completely dedicated to problems like this. All your requirements are dealt with, including instationary calculation over time. EnergyPlus is capable of individual room-resolved heat load calculations etc., and there is a rather large library of construction materials with their thermodynamic properties.
Regards,
Peter
petroo is offline   Reply With Quote
Old   October 19, 2010, 07:56
maysmech's Avatar
maysmech is on a distinguished road
hi,
One question:
Can buoyantBousinesqPimpleFoam solver handle a room ventilation simulation with inlet velocity(Fan, Cooler, Heater, ...) and pressure outlet (Door) with temperature (Energy equation)?
i asked this question because i didn't see any tutorial file case same as the case i told and all of them are same as hot room with a hot section without any forced flow like fan.
Best,
Maysam
maysmech is offline   Reply With Quote
Old   October 20, 2010, 06:53
Eugene de Villiers
Yes it can. Your boundary conditions will depend on your version of OpenFOAM though.
Old   October 21, 2010, 05:57
maysmech's Avatar
Thanks Eugene,
i need a solver to simulate a room ventilation with inlet and outlet. the most similar solver i found was Heat Transfer solvers like buoyantBousinesqPimpleFoam. but i don't know why it doesn't understand the flow temperature for example i run it for a room with inlet fan with colder T than room but the flow effects on temperature was not real physically i think it set temperature of fan as a fixed wall instead of setting inlet patch flow temperature as desired T. Also velocity contour shows velocity to top in below of fan and it couldn't be true.
Old   October 21, 2010, 12:41
Eugene de Villiers
The solver you used should give ok answers for the problem you described. Not sure why its not working.
Old   October 21, 2010, 17:36
Question
  #12
maysmech's Avatar
Here is geometry of the problem.
It is a room with 6 inlet fans at ceiling with T=290K and U=0.1 m/s. A window with 305 K is shown and walls and door have zeroGradient temperature.
After solving for 120 sec with time step of 0.1 the solution is:
and in real it is not acceptable to have T over all other temperatures. also contour of U_Z shows velocity to top instead of down of room in below of fans
I don't know where does the problem come form? the first thing i think is the solver may be not suitable for simulating flow with inlet and outlet with temperature like modeling of a room ventilation.
Old   October 22, 2010, 04:51
Eugene de Villiers
Are you sure your fans are blowing into and not out of the room?
Old   October 22, 2010, 05:57
maysmech's Avatar
Yes, in boundary cells of fans u_z is -0.1 but below of them u_z is positive to up and shows a circulating flow to both sides of fan.
Old   October 23, 2010, 21:48
Hasselhoff is on a distinguished road
Did you check your gravity settings? Tell us if you solved that problem, I was dealing with quite a similar problem some time ago.
Hasselhoff is offline   Reply With Quote
Old   October 24, 2010, 01:57
maysmech's Avatar
Old   October 24, 2010, 02:22
maysmech's Avatar
hi,
Gravity is -9.81 m/s2 as default.
when i increase the fans inlet velocity from 0.1 to 1 the velocity contour along z is more acceptable. i mean in u_z=-0.1 velocity near ceiling fans is to up but for u_z=-1 is to down and i think it is because of changing dominant between buoyancy (U to up) and inlet fan velocity (to down). I am not sure about this. Any more comment will be appreciated.
Old   October 24, 2010, 04:17
In my case, the cold air from the radiators sinks down to the floor as it is supposed to be. Maybe the 0.1m/s is just too weak of a flow in your case. Or maybe your domain bounding box is scaled too big?
Good luck..
/M
Old   October 24, 2010, 06:02
maysmech's Avatar
The other problem is how can we define T B.C for windows.
I think fixedValue is not a good assumption for windows temperature.
JuanRodriguez likes this.
Old   October 24, 2010, 08:45
For windows I use heat flux boundaries. What kind of turbulence model are you using?
Conductive Heat Transfer in OpenFoam? FloK OpenFOAM 8 March 18, 2011 13:51
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 05:56
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
