Laplacian of a TensorField ?
Old   September 23, 2010, 07:11
Post Laplacian of a TensorField ?
T.D. is on a distinguished road
How to calculate laplacian of A*T
if A is a scalar function of another scalar Main field c and , T is a 2nd order tensor
example
when i put
solve
fvm::ddt(c) + fvm::div(phi,c) == fvm::laplacian(A,T)
A=2*pow(c,2)+5;
it doesnot work!!!!?
Help lease??
T.D. is offline   Reply With Quote
Old   September 23, 2010, 07:18
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
Originally Posted by T.D. View Post
solve
so what you are saying is
scalar + scalar == tensor
I hope you see the mistake here
niklas is offline   Reply With Quote
Old   September 23, 2010, 08:02
Smile Hi
Execuse me,
In another words
the last term to the write is
∇·(A*(∇.T)) which must be a scalar ok to go on with the c equation.
where A is a scalar and T is a second order tensor
so ∇·T is div(T) and it is a vector ok (since divergence of a tensor) ??
and V=A*∇·T is a vector then
so ∇·(A*(∇.T)) must be written something like div(A,V) ?? knowing that A is always a function of c.
helpme
Thanks
Old   September 23, 2010, 08:14
niklas's Avatar
Niklas Nordin
∇·(A*(∇.T))
ah ok, so its 2 div operations...
∇·(A*(∇.T)) = fvc::div(A*fvc::div(T))
but this will make this term fully explicit.
I think it will be hard to treat it fully implicit.
If you run into stability problems you should try to split it up into implicit/explicit parts.
Old   September 23, 2010, 09:43
Post HI
Hi Niklas thanks,
BUT A is a function of the scalar field c.
so it stays like that ∇·(A*(∇.T)) = fvc::div(A*fvc::div(T)) ??
another thing please: do you know how to turn off all dimensions?
thank you so much
Old   September 23, 2010, 09:54
niklas's Avatar
Niklas Nordin
yes of course it does.
and why do you want to turn off dimensions,
it has saved me on numerous occasions.
but ok, I can see that the exp-function can give you problems.
if you are using 1.7.1 it is in
OpenFoam-1.7.1/etc/controlDict
lookup the line
dimensionSet 1;
and change the 1 to 0.
Old   September 23, 2010, 12:40
Default Thanks
Thanks a lot Niklas
Modifying the laplacian operator mlawson OpenFOAM Running, Solving & CFD 22 July 16, 2018 04:56
why laplacian() failed OFCrash OpenFOAM Running, Solving & CFD 1 February 1, 2010 07:32
Probable bug with laplacian steady state novyno OpenFOAM 1 November 23, 2009 19:31
Laplacian operator and nuSgs for heat equation Bedotto OpenFOAM Programming & Development 4 September 7, 2009 15:08
Implementation of div, laplacian, etc and variables sven OpenFOAM 3 July 19, 2009 18:18
