Monitoring at Runtime
Old   October 13, 2010, 05:13
Default Monitoring at Runtime
Olli
Moelfus is on a distinguished road
Hi Foamers,
I have got a small question. I want to monitor some parts of my simulation, like points, surfaces and if possible lines. So I can draw a comparison to the measurements during the run. For points and surfaces I just added function{...} into the controlDict. I'm using OF 1.7. I would guess it is possible to extract lines as well, but I didn't get it set up correctly. Maybe someone has a small code-snippet for me.
Regards Olli
Excerpt from controlDict:
functions
    probes
        type            probes;
        functionObjectLibs ("libsampling.so");
        enabled         true;
        outputControl   timeStep;
        outputInterval  1;
        probeLocations
            ( 0.0275 0.020625 0)
            ( 0.0275 -0.020625 0 )
            ( 0.0275 0 0.020625 )
            ( 0.0275 0 -0.020625 )
            ( 0.055 0.030 0 )
            ( 0.055 -0.030 0 )
            ( 0.055 0 0.030 )
            ( 0.055 0 -0.030 )
        fields
	    U
            p
    probes
    type            surfaces;
        enabled         true;
        outputInterval  1000;
    surfaceFormat raw;
    interpolationScheme cellPointFace;
        fields
            U
    surfaces
            xyPlane
        type plane;
        basePoint (0 0 0);
        normalVector (0 0 1);
	  xzPlane
	  type plane;
	  basePoint (0 0 0);
	  normalVector (0 1 0);
Moelfus is offline   Reply With Quote
functions, libsampling, monitor
monitoring point of total temperature rogbrito FLUENT 0 June 21, 2009 17:31
saving monitoring data mange FLUENT 2 March 3, 2009 05:54
Problem with surface monitoring vitmalin FLUENT 0 March 23, 2005 12:49
Fortran Runtime Dadou Siemens 0 April 1, 2004 07:02
monitoring cell Jane Siemens 2 March 4, 2004 21:01
