gen6DoF
Old   November 8, 2010, 10:23
Default gen6DoF
afo3 is on a distinguished road
hello everybody,
anyone can explain me how to set up the application gen6DoF for my simulations? it stands in the sloshingTank6DoF tutorial.
thanks!
afo3 is offline   Reply With Quote
Old   November 8, 2010, 11:20
SOLVED.
build the application with wmake.
open the file gen6DoF.C and set your case.
run it with gen6DoF. it will create a 6DoF.dat
this is if you want that your mesh move as input.
now the questions are:
- how can I set up the dynamicMeshDict in order to move just a part of the mesh and not all the control volume?
- if the movement of the mesh is one of the output datas, what kind of dynamicFvMesh is to be setted in dynamicMeshDict instead of SKA?
Old   November 21, 2015, 00:37
Default Fixing axis of rotation
hydraulist is on a distinguished road
I'm posting my query in the existing post because it is related to the same topic. I'm a beginner in OF and i couldn't get exact clarity for my doubt from other posts. I apologize if it is very well explained already.
Could you tell me the default axis of rotational oscillation in gen6DoF application? Is it the CofG (Center of gravity) which is the axis of rotations. What could be done if i wanted to change the axis of rotation of a tank? Thanking you.
hydraulist is offline   Reply With Quote
