potentialFoam around a sphere ; mesh by Gmsh
Old   April 23, 2009, 10:50
Default potentialFoam around a sphere ; mesh by Gmsh
Eliam H
eliam is on a distinguished road
Hi all
I'm new in OpenFOAM. I use it for an automotive application but I want to begin with easier cases.
I'm trying to study the flow around a sphere with potentialFoam (as a begin).
I made my sphere with blender, exported it in STL format.
I make the fluid domain and the mesh with Gmsh.
I import the .msh file with gmsh2ToFoam.
checkMesh give me OK in spite of non-orthogonal faces.
potentialFoam seems to work well.
But when I posttreat the results I see that the velocity magnitude reach more than 7000 m/s (I had 40 m/s in inlet, with 1 m/s it reaches more than 1000 m/s).
I run the potentialFoam/cylinder example case whithout any problem.
I think that the problem comes from the mesh but I don't know any more where to look for.
My case folder is online at : http://eherichon.perso.ec-marseille....le/gmsh.tar.gz (4.1 M)
Any help would be welcome .
Thank you
Eliam
eliam is offline   Reply With Quote
Old   April 24, 2009, 05:33
Eliam H
Hi all
I just tried my case with a mesh generated by snappyHexMesh from the same STL sphere. I have now "good" results.
So the problem come from the mesh.
Maybe the topic should be moved to the mesh part. Sorry.
Has somebody idea to generate a "good" mesh with Gmesh ? (or other OpenSource Mesher).
Thanks.
Eliam
Old   April 24, 2009, 09:06
Eliam H
Checking two options in Gmesh I get a good mesh :
Tools / Options / Mesh / Advanced
- Optimize quality of tetraedra
- Optimize quality of tetraedra with NetGen
Old   July 27, 2009, 20:31
J. Cai
chiven is on a distinguished road
Hi, Eliam, I meet the same problem just like yours. My mesh is converted from Fluent. checkMesh also give me OK, and potentialFoam seems to work well.
However some velocity magnitudes reach very large (over 1e+06).
And my case is very complicated, I am not sure it can be generated by snappyHexMesh. Do you have any comments?
Thank you.
Chiven
chiven is offline   Reply With Quote
Old   July 28, 2009, 02:36
Eliam H
Hi Chiven.
"Ok" by checkMesh seems to be not enough. Have you non-orthogonal faces ?
Old   July 28, 2009, 03:00
J. Cai
Hi, Eliam, thanks for your friendly reply. The follows are the prompt when run checkMesh.
Best regards,
Chiven
Create polyMesh for time = constant
Time = constant
Mesh stats
faces: 3121097
internal faces: 2980747
cells: 1525461
boundary patches: 7
point zones: 0
face zones: 0
cell zones: 0
Number of cells of each type:
hexahedra: 0
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 1525461
polyhedra: 0
Checking topology...
Boundary definition OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
Patch Faces Points Surface topology
wall 134626 67762 ok (non-closed singly connected)
pump-in 334 200 ok (non-closed singly connected)
ec-in 54 37 ok (non-closed singly connected)
dc-left 1218 703 ok (non-closed singly connected)
dc-bot 1450 849 ok (non-closed singly connected)
dc-right 1220 704 ok (non-closed singly connected)
dc-top 1448 848 ok (non-closed singly connected)
Checking geometry...
Overall domain bounding box (-0.32 -0.1035 -0.5) (2.90989 2.38459 0.2)
Mesh (non-empty) directions (1 1 1)
Mesh (non-empty, non-wedge) dimensions 3
Boundary openness (4.85517e-17 2.16681e-16 1.84246e-17) OK.
Max cell openness = 2.71454e-16 OK.
Max aspect ratio = 8.39433 OK.
Minumum face area = 7.73192e-06. Maximum face area = 0.000113308. Face area magnitudes OK.
Min volume = 1.21101e-08. Max volume = 3.44939e-07. Total volume = 0.151526. Cell volumes OK.
Mesh non-orthogonality Max: 66.6416 average: 19.7369
Non-orthogonality check OK.
Face pyramids OK.
Max skewness = 0.956777 OK.
Mesh OK.
Old   July 28, 2009, 06:02
Eliam H
Your mesh seems good. Have you post-processed your case to see the zone where the velocity is weirb ?
I don't use OpenFOAM for several months so I don't remember very good all the tricks I discovered.
But reading your report again I wonder if your max skewness isn't a little high. (try to be under 0.85).
Good luck !
Old   July 28, 2009, 06:19
Smile
J. Cai
Hi, dear Eliam, thank you very much for you precious time and patience. I do have seen the velocity distribution from paraFoam. The form of my case is not so regular. I am wondering whether OpenFoam can deal with so much complicated case.
Thank you again.
best regards,
Chiven
Old   July 28, 2009, 07:40
Eliam H
Hi Chiven
I'm not a specialist but I think that OpenFoam can compute complicated cases. (see the examples on the website) but you need a very good mesh.
Have you compared the areas where you have high value of velocity and areas where you have high skewness ?
Old   July 28, 2009, 09:41
J. Cai
Hi, Eliam, I have checked the areas with large velocity, and written a report, and sent to my boss. I shall discuss with him tomorrow. It is time of 10:41 PM in Japan. However, about the skewness, I can not check it, my fluent mesh is from my boss. And I shall also discuss this point with him. When I solve this problem, I shall also tell you the answer.
Good news, the release 1.6 is published! There are many new funcitons.
By the way, what is the experted engineering case using OpenFoam? Many people have also asked me what are the most successful engineering application examples by OpenFoam. But my computer is not able to open the Examples_of_Application webpage, maybe I can do it in my dormitory. I found many people only used OpenFoam to do some simple cases, and stopped.
Thank you very much.
Best regards,
Chiven
Old   January 4, 2011, 09:57
Unhappy
  #11
Tao Zhu
kongfu is on a distinguished road
Originally Posted by eliam View Post
Hi Chiven.
Hi Eliam,
I have the same problem. I'm using Tetrahedron meshs, and some velocity magnitudes are 10000 after potentialFoam. My inlet velocity is just 69.
Do you think it's probably the problem of mesh? Number of non-orthogonal faces: 109669
kongfu is offline   Reply With Quote
Old   January 5, 2011, 06:39
Eliam H
Try to have no more non-orthogonale faces ;-)
Old   January 26, 2011, 03:02
Matej Andrejasic
MatejAndrej is on a distinguished road
Hello Eliam
Can you please share with me your initial and boundary conditions you used for potential flow around the sphere or something else. It seem's I have some problems at boundary.
Thank you in advance.
Matej
MatejAndrej is offline   Reply With Quote
Converting mesh from gmsh newbee OpenFOAM Pre-Processing 21 January 22, 2010 06:51
hexa mesh around a sphere within a cylinder:fluent HK Main CFD Forum 1 March 20, 2008 10:54
ICEM 10 mesh question DAK565656 CFX 6 May 8, 2007 12:16
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
Mesh distortion close to cylind wall-GAMBIT 2.2.30 Mirek FLUENT 1 April 15, 2006 17:22
