Variation of y+ on aerofoil surface
Old   February 8, 2011, 11:55
Default Variation of y+ on aerofoil surface
Richard Moser
moser_r is on a distinguished road
I am running a 2D aerofoil case, meshed with blockMesh, and using wall functions. I have found various sources that say that the y+ should be in the range 30 < y+ < 200 (the exact numbers vary slightly depending on the source, but that isn't the issue). Since I am using blockMesh, my first cell is the same height all around the surface. Therefore, I am getting a wide variation in y+. In order to get the minimum y+ above 30, the first cell height is such that I get a maximum y+ > 600. Is this reasonable, or what values of y+ should I be aiming for?
moser_r is offline   Reply With Quote
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
Variation In Water Surface Elevation Umm... FLUENT 0 December 10, 2007 00:14
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
