Parallel running needs more iterations?
Like Tree4Likes
  • 4 Post By arjun
Old   March 26, 2011, 07:09
Default Parallel running needs more iterations?
Zoltan Hernadi
zhernadi is on a distinguished road
Dear OpenFOAM community,
I am testing parallel scalability on different machines and I found that sub-linear scaling may be caused by an increase of iterations.
In the attachments you can find my study based on 'cavity' case:
- iterations.png: Comparison of number of iterations: single/parallel
- iterations-case.zip: OpenFOAM 1.7.1 case (If you want to repeat my test, you will need gnuplot for plotting. Calculation should take less than 2 minutes.)
Questions:
1. Why does the solver need more iterations when solving a case in parallel?
2. Do you experience the same behavior in your CFD problems?
3. How can we change convergence criteria in order to have the same (or approx. same) number of iterations for the parallel run as we had for the single run?
4. Are there other possibilities to reduce this undesirable effect?
Thanks,
Zoltan
zhernadi is offline   Reply With Quote
Old   March 27, 2011, 04:19
Alberto Passalacqua
Does "pIters" refer to the iterations on the pressure equation?
Alberto Passalacqua
Old   March 27, 2011, 07:01
Máté Márton LOHÁSZ
lohasz is on a distinguished road
Yes "pIters" refers to the number of iterations on the pressure equation.
Máté (a colleague of Zoltán, this is the reason I know the answer as well)
lohasz is offline   Reply With Quote
Old   March 27, 2011, 21:38
Arjun
arjun will become famous soon enougharjun will become famous soon enough
with assumption that program has no bugs related to parallel programing.
Questions:
It depends on your matrix solver for pressure correction equation. Some matrix solvers require more iterations in parallel mode.
It is known problem.
Again it all depends on what matrix solver you are using. In some cases , it is not possible to change this behaviour. You have to increase iterations in matrix solver.
yes, www.columbia.edu/~ma2325/poly.ps
arjun is offline   Reply With Quote
iterations, parallel
Velocity blows up suddenly after 30,000+ iterations lordvon OpenFOAM Running, Solving & CFD 15 October 19, 2015 13:52
reactingFoam: adiabatic flame temperature rFkhemek OpenFOAM 2 July 31, 2009 06:42
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Automatic Mesh Motion solver michele OpenFOAM Running, Solving & CFD 10 September 26, 2005 08:21
