Pressure in Channel with simpleFoam and cyclic
Like Tree1Likes
  • 1 Post By ArathoN
Old   November 2, 2014, 18:30
Default Pressure in Channel with simpleFoam and cyclic
ArathoN
ArathoN is on a distinguished road
I've done some simulations over a channel using RANS models first with pimpleFoam however because of some problems i switched to simpleFoam (here the thread i created for pimple link)with cyclic Boundaries. I noticed:
  1. it's hard to lower the residuals of pressure and Uy. Tightening the fvsolution tolerances and lowering aspect ratio may help. For Re=15000 this approach worked and the residual decrease to 1e-6 however for Re=64000 i couldn't accomplish this no matter what scheme or IC i've put.
  2. the profile of the Uy and p residuals present an oscillatory behavior they systematically have peaks.
  3. The pressure field is weird (see pictures LS stand for launderSharmaKE and SSY for kOmegaSST) i don't know why it is like that
  4. tHe pressure gradient at the first step is always high and Ubar is alway low after some time they will stabilize.
Does any of you have an explanation about this p field? I'm really lost here.
For the info on the flow i'll link the other thread link
ArathoN is offline   Reply With Quote
Old   November 4, 2014, 07:23
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Hey,
I see the same for a periodic pipe, LaunderSharmaKE
This is a cut through the (short) pipe. Upper profile is "U", flow goes in "x"-direction. X-direction is very poorly resolved by the mesh (see the lower pressure profile). Here you also see the wiggles.
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   November 4, 2014, 17:40
ArathoN
I refined the mesh along x and y direction but the pressure still had that same behavior. I searched more on the forum and in the net but didn't find anything useful. Maybe The pressure gradient source is bugged with simpleFoam, I'll check my case with pimplefoam and report back.
Old   November 7, 2014, 10:08
davide basso
rolloblues is on a distinguished road
This is what my residuals and middle plane profiles of velocity and pressure look like (simpleFoam, Re=44000 approx)
The inlet patch is at the bottom and it is mapped with the top outlet patch.
I didn't use cyclic boundary conditions for inlet and outlet since it would have killed the pressure gradient between in and out.
If you did maybe that's the reason for those strange behaviours. Infact especially in ArathoN's there is barely any pressure gradient at all
rolloblues is offline   Reply With Quote
Old   November 14, 2014, 12:41
ArathoN
Can you upload your /0 folder, I tried to use mappedBC but I had very bad residual. The mapped variable oscillates around 0.01-0.1 almost like your U. In my case I mapped all the field variables except for nut and I mapped to the nearest cell of the outlet (I've put the offset a Lil bit away from the inlet position, I've read that it can cause problems if you put it at the exact position of the outlet). I'll try to do the simulation again and I'll report, for now the u-profile is quite good.
Old   November 14, 2014, 13:04
davide basso
There you go
Old   November 14, 2014, 13:23
ArathoN
Originally Posted by rolloblues View Post
There you go
Interesting you set average values to 0. Is this right? I usually set that flag to false. What interpolation did you use in block mesh dictionary for mappedPatch.
Old   November 14, 2014, 14:00
davide basso
I can't give you reference about the zero value for the average. To be honest since the thing worked I didn't pay much attention to it.
Regarding block mesh dictionary I used:
sampleRegion region0;
sampleMode nearestPatchFace;
samplePatch top_end;
Old   November 14, 2014, 17:10
ArathoN
Ah interesting didn't know you can directly specify the patch from which to sample. I usually used the offset option. Thanks I'll try tonight with mappedPatch and I'll report tomorrow.
Old   November 21, 2014, 22:25
ArathoN
I confirm with mapped patch the pressure field is perfect however the residuals will have an oscillatory behaviour and they will not converge to 1e-6. I compared the U-profile of the mappedpatch and cyclic cases and they are identical.
So in the end the pressure field behavior with cyclic is a problem of how the fvOption works with the solver simpleFoam. In my opinion it is needed a pressure correction loop to reassess the continuity.
P. S ah because I made the same error in blockmeshdict it is needed to set the offset value for mappedPatch otherwise it will not work. Moreover if setaverage is 0 there is no averaging.
pm11dt likes this.
Old   December 8, 2018, 06:25
M. Montero
be_inspired is on a distinguished road
Could you explain this point?
I am facing convergence problem in the pressure equation when using cyclic bc
be_inspired is offline   Reply With Quote
How to setup cyclic BCs in simpleFOAM hhuang84 OpenFOAM Running, Solving & CFD 14 December 8, 2016 11:39
fully developed channel with cyclic using simplefoam ArathoN OpenFOAM Running, Solving & CFD 4 February 21, 2014 09:53
ribbed channel / simpleFoam / boundary conditions beeo OpenFOAM Pre-Processing 20 July 17, 2013 08:39
Cyclic boundary conditions concerning channel with constant flow rate pascool OpenFOAM Pre-Processing 1 November 16, 2012 13:04
multiple cyclic fans and outlets irregular ( checkerboard ) pressure on patch faces ajl42 OpenFOAM 0 November 30, 2011 08:05
