Fixed heat flux BC in buoyantPimpleFoam
Like Tree30Likes
Old   March 31, 2011, 09:10
Default Fixed heat flux BC in buoyantPimpleFoam
bhh
Bjorn H. Hjertager
bhh is on a distinguished road
I am running buoyantPimpleFoam with a built-in boundary condition for heat transfer based on heat transfer coefficient (aphaWall) and outside temperature (Tinf) like this:
window
type wallHeatTransfer;
alphaWall uniform 1.5;
Tinf uniform 263;
value uniform 293.;
This work perfectly.
Now I want to impose a fixed heat flux ( eg 50 W/sq m) on a patch (radiator). How do I do this in the solver? Is there a built-in BC condition for this. I know that the solver demands boundary conditions for temperature but the enthalpy is used for solving the energy equation.
Can anybody give me a hint?
Regards
Bjorn
Ramzy1990 likes this.
bhh is offline   Reply With Quote
Old   March 31, 2011, 10:26
Aram Amouzandeh
mabinty is on a distinguished road
Hi!
Check out this BC (for RAS turbulence models): src/turbulenceModels/compressible/RAS/derivedFvPatchFields/turbulentHeatFluxTemperature. It applies for the heated boundary patch as a temperature boundary condition like that:
heatedPatch
    type              compressible::turbulentHeatFluxTemperature;
    heatSource    power;
    q                   uniform 65.0;
    value             uniform 293.0;
cheers,
Aram
vishal, bhh, yossi and 8 others like this.
mabinty is offline   Reply With Quote
Old   March 31, 2011, 11:18
bhh
Bjorn H. Hjertager
Hi Aram!
It works like a charm! Thank you very much
rgds
Bjorn
Old   March 31, 2011, 21:54
bhh
Bjorn H. Hjertager
Hi Aram,
One thing that is unclear about the BC: is power q given in Watts or Watts per sq m for the patch in question?
rgds
Bjorn
Old   April 1, 2011, 03:28
Aram Amouzandeh
hi bjorn!
see src/turbulenceModels/compressible/RAS/derivedFvPatchFields/turbulentHeatFluxTemperature/turbulentHeatFluxTemperatureFvPatchScalarField.C lines 176 - 202. if you set
heatSource  power;
q stands for power (W); in case of
heatSource  flux;
q is taken as power density (W/m2).
cheers!
aram
vishal, bhh, Mojtaba.a and 5 others like this.
Old   April 1, 2011, 04:52
bhh
Bjorn H. Hjertager
Hi Aram,
Thanks again! This clarified the situation
rgds
Bjorn
Old   April 1, 2011, 22:41
MSR CHANDRA MURTHY
chandramurthy is on a distinguished road
Dear Aram,
In the calculation of gradient() [ turbulentHeatFluxTemperatureFvPatchScalarField.C, lines 180 and 185 ], effective thermal conductivity is calculated as (Cp*alphaEff). I guess it should have been (Cp*alphaEff.Rho).
mgg likes this.
chandramurthy is offline   Reply With Quote
Old   April 1, 2011, 22:44
MSR CHANDRA MURTHY
Please read (Cp*alphaEff.Rho) as (Cp*alphaEff*Rho)
Old   April 4, 2011, 04:02
Aram Amouzandeh
hi!
alpha = a*rho = k/cp (kg/s/m) denotes the effective enthalpy (energy) diffusivity, whereas "a" (m^2/s) stands for the thermal diffusivity. hence, conductivity k = cp*alpha.
cheers,
aram
Old   June 7, 2011, 00:36
Kevin
murrdpirate is on a distinguished road
heatedPatch
    heatSource    power;
    q                   uniform 65.0;
What exactly is the temperature value for? Does it change the flux value? I implemented this bc into one of my projects, but I forgot to change the temperature and I ended up with a wall that was at a lower temperature than the internal field. Is it still transferring 65 W to the internal field?
murrdpirate is offline   Reply With Quote
Old   June 7, 2011, 02:51
Aram Amouzandeh
Originally Posted by murrdpirate View Post
heatedPatch
    heatSource    power;
    q                   uniform 65.0;
is used as initial value at the respective patch. To check wall heat fluxes use the "wallHeatFlux" utility.
Aram
murrdpirate likes this.
Old   June 10, 2011, 05:24
Default Setting a variable heat flux for laminar flow
  #12
Matthias Hettel
matthi is on a distinguished road
I´m relatively new in applying OpenFoam.
My question is if anyone can give me an advice where I have to search if I want to apply a heat flux to walls in case of laminar flows (solver rhoSimpleFoam). I`d like to have access to all wall cells and want to set a different heat flux for every cell according to values which I get from somewhere else (measured or calculated data).
I think an approach like using
would be right. But I can use this only for turbulent flows ?
Or do you think that I could use a RAS-code for laminar flow and replace the values Ap, Cpp, alphaEffp in such a manner that I get the desired heat flux?
Thanks in advance for any information
Matthias
matthi is offline   Reply With Quote
Old   June 10, 2011, 08:44
MSR CHANDRA MURTHY
Nearest matching BC for your requirement is timeVaryingMappedFixedValue. You have to tweak around slightly to make it timeVaryingMappedFixedHeatFlux. in base class inherit fixedGradient instead fixedValue.
Matthias
Old   June 10, 2011, 09:38
Matthias Hettel
Hi Chandramurthy,
many thanks for your reply. I got also an other advice from Aran (see above). He wrote me, that I should govern the laminar heat flux with the temperature gradient (Fourier's law) on the respective patch (fixedGradient).
I`ll search in both ways ... but ... as I`m a beginner it will take a lot of time to succeed. If I will be successful I will post the result in the forum.
Greetings Matthias
Old   June 14, 2011, 17:11
Kevin
It appears that the turbulentHeatFluxTemperature only works for heat gains and not heat losses, is that correct? Or am I doing something wrong? I just tried making the "q" value a negative number, but I get a heat gain. Is there a way to make this work or am I stuck with temperature gradients?
Old   June 15, 2011, 09:48
Matthias Hettel
Hi Kevin,
it should work in both ways (for positive and negative gradient). This would be physically and numerically right. Maybe, the code uses somewhere only the absolute value of and nobody tried it before, or you made something wrong. The flux is not independent from your coordinate system ! Be sure that you "think" in the right direction.
Greetings Matthias
Old   June 29, 2011, 23:14
Kevin
Matthais,
Sorry, I forgot that I never got back to you. You are correct that this BC handles negative heat transfer. At one point, I did see what appeared to be heat gain, but I think somehow my turbulence model was causing it to create pockets of heat (and a heat loss overall). Thanks for your help.
Old   June 30, 2011, 00:18
Kevin
It looks like this boundary condition has changed in ver 2.0. I now get the error "Keyword K is undefined in [my boundary condition]" Anyone know what that means?
Old   June 30, 2011, 01:18
Aram Amouzandeh
That means you did not specify how the conductivity fied "K" shoud be calculated. Look at the top of src/turbulenceModels/compressible/turbulenceModel/derivedFvPatchFields/turbulentHeatFluxTemperature/turbulentHeatFluxTemperatureFvPatchScalarField.H:
hotWall
            heatSource      flux;        // power [W]; flux [W/m2]
            q               uniform 10;  // heat power or flux
            K               basicThermo; // calculate K by alphaEff*thermo.Cp
            value           uniform 300; // initial temperature value
Cheers,
Aram
murrdpirate, socrates and JR22 like this.
Old   June 30, 2011, 02:00
Kevin
Thanks. I didn't realize there were examples in the code for these things.
Issue now is that it's saying "KName is undefined." As you showed, that's not listed in the example. I see somewhere online that it's "CHARACTER*(*) array of species names," but I don't know what that means
Total heat transf. rate vs Total surface heat flux Renato Sousa FLUENT 1 April 14, 2020 03:27
Sign of Heat Flux at wall Kyung FLUENT 2 February 26, 2016 16:25
Variable name for heat flux peterle CFX 4 February 13, 2014 02:21
Heat Flux Wall Boundary Confusion. Joee FLUENT 1 August 21, 2010 12:20
Heat flux in ansys cfx juliom OpenFOAM Running, Solving & CFD 2 April 14, 2009 14:30
