rhoSimpleFoam convergence problem
Old   May 21, 2011, 04:03
Default rhoSimpleFoam convergence problem
Hanan Einav-Levy
hananfoam is on a distinguished road
I am trying to solve the simple case of laminar flow in a tube.
basically what is described here
http://www.somogyibence.hu/documents.../Cornell1.html ,
only i wish to have a heated wall and so the density should change, so I looked at the openFoam solvers, and chose rhoSimpleFoam.
I have given the same equivalent BCs as in the link above, and also played with inletoutlet type BCs, but with out success, i can not get convergence and i see that the pressure is the main problem, it oscilates all the time and never convereges (together with Ux, the velocity in the axial direction).
I am looking for suggestions on relaxation factors, or anything else that is the correct way to get a solution for this simulation (mesh suggestions?, it's simply a blockmesh with simpleGrading (1 1 1 ) )
Thanks,
Hanan.
hananfoam is offline   Reply With Quote
Old   May 25, 2011, 11:03
David Gaden
marupio is on a distinguished road
Two grasp-at-straws suggestions:
- Play with the gravity. Start with a low value, and increment it, using the latest solution each time. This may smooth out the instabilities.
- Try using a transient algorithm, and look for steady state conditions to develop.
marupio is offline   Reply With Quote
Old   May 25, 2011, 16:34
Default Thanks, i'll try it
Hanan Einav-Levy
can you point out a suitable transient algorithm? i'm still not very familiar with the different solution algorithms.
Old   May 25, 2011, 16:57
David Gaden
Is there a buoyant piso? Or "pimple"? In OpenFOAM, "SIMPLE" is the chosen steady state algorithm, "PISO" is the chosen transient one. "PIMPLE" is OpenFOAM's own (unfortunately named) algorithm that I believe will switch between PISO and SIMPLE depending on the case directory.
Old   May 25, 2011, 17:07
Hanan Einav-Levy
oh, got ya.
will try.
heated wall, laminar, pipe flow, rhosimplefoam, tube flow
convergence problem when use pisoFoam, LES for wind tunnel case Forrest_Lei OpenFOAM 3 July 19, 2011 06:00
convergence problem commonyue Main CFD Forum 1 December 1, 2009 03:54
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
3D Fluid Flow Convergence problem Emily FLUENT 2 March 21, 2007 22:18
Non Convergence of 3D Heat transfer cfd problem Balraj Main CFD Forum 3 December 9, 2004 00:24
